Solving Trinomial Factoring Problems: Tips and Tricks"
  • Thread starter Hollysmoke
  • Tags
    Factoring
In summary, my friends and I were stumped trying to figure out this equation. We were taught it in school, but we're not sure how to factor it out. When we tried to factor it out, we got the wrong answer. We substituted a^2-5a for y and got an expression in terms of a and not y. After substituting back into the original equation, we got the decompositions (a^{2}-5a)^{2}+8(a^{2}-5a)+12=(a^{2}-5a+2)(a^{2}-5a+6)=(a^{2}-5a+2)(a-2)(a-3
Hollysmoke
185
I asked my friends about this and they were stumped too.
(a^2-5a)^2 + 8(a^2-5a)+12
Since it's a trinomial, I tried to do decomposition but it didn't work. I tried to factor out the (a^2-5a) but I end up with a different answer then on the sheet.
Set y=a^2-5a.
Factorize your expresion in terms of y first
so would it be ax^2+bx+c=0?
x presumably meaning y, yes, you'll see how to factorize the polynomial once you've found the roots of your cited equation, with the relevant values for "a,b,c"
("a" NOT meaning the same here as above).
would it be 1,8 and 12?
That is correct.
But where do I go from there? My friendsa nd I are stumped. Our teacher never taught us this >_>
What are the roots of the equation:
[tex]y^{2}+8*y+12=0[/tex]?
How can you therefore factorize the polynomial [itex]y^{2}+8y+12[/itex]?
(y+4)(y+3)=0
No. Try again.
err whoops
(y+2)(y+6)=0
I got the decomposition mixed up (which term to add up and which to multiply)
So, you've factorized the left hand side of your EQUATION correctly.
How is thereby the POLYNOMIAL [itex]y^{2}+8y+12[/itex] factorized?
I'm not sure what you are asking for, I thought I just factored the polynomial
OK:
For ANY number y, we have the identity [itex]y^{2}+8y+12=(y+2)(y+6)[/tex]
This is to factorize the POLYNOMIAL.
The two numbers -2 and -6 are the solutions Y for the equation [itex]Y^{2}+8Y+12=0[/itex]
Do you agree with that?
Right, I understand that part. (Sorry if I'm a bit slow)
That's okay.
Now that you've factorized your polynomial in y, substitute into its factorized form (y+2)(y+6) on the y-places y=a^2-5a.
What do you get then?
In particular, can you do some further factorizations?
so would it be (a^2-5a)(a+2)(a+6)?
Eeh, why??
Have you placed the expression a^2-5a into the y-places correctly, do you think?
OH...is it...(a^2-5a)(a-2)(a-3)?
No.
You have (y+2)(y+6)
If you substitute the y's in that expression using the equality y=a^2-5a, what do you get?
You should read all the posts here again, Hollysmoke:
You need to factor [tex](a ^ 2 - 5a) ^ 2 + 8(a ^ 2 - 5a) + 12[/tex].
So you notice that a2 - 5a appears twice, you may want to make your expression have a nicer look.
So you'll let: [tex]y = a ^ 2 - 5a[/tex], your expression suddenly becomes:
y2 + 8y + 12, which can be factored to (y + 2) (y + 6). It looks nicer, right?
Now, having let: y = a2 - 5a, you should substitute that back to the expression (y + 2) (y + 6) to get some expression in terms of a, instead of y.
After substituting, can the expression can be factored more?
oops sorry...I forgot to post my Thanks >_<
Okay, do you agree that with substituting a^2-5a for y, we get:
[tex](a^{2}-5a+2)(a^{2}-5a+6)[/tex] ?
Yup. Then u use decomposition for the 2nd term, resulting in (a-2)(a-3)
Quite so. Thus, you've got the decompositions:
[tex](a^{2}-5a)^{2}+8(a^{2}-5a)+12=(a^{2}-5a+2)(a^{2}-5a+6)=(a^{2}-5a+2)(a-2)(a-3)[/tex]
Now, try and decompose the factor [itex](a^{2}-5a+2)[/tex] in a similar manner, and you're done.
What is trinomial factoring?
Trinomial factoring is the process of breaking down a polynomial with three terms into its factors. It is a fundamental skill in algebra and is used to solve equations and simplify expressions.
Why is trinomial factoring important?
Trinomial factoring is important because it allows us to solve more complex algebraic equations and simplify expressions. It is also a crucial skill for higher-level math courses and real-world applications.
What are some tips for solving trinomial factoring problems?
Some tips for solving trinomial factoring problems include looking for common factors, using the FOIL method, and checking for special cases such as perfect squares.
What are some common mistakes to avoid when solving trinomial factoring problems?
Common mistakes to avoid when solving trinomial factoring problems include forgetting to check for common factors, incorrectly applying the FOIL method, and forgetting to include the sign in front of the middle term.
Are there any tricks to make trinomial factoring easier?
Yes, there are some tricks that can make trinomial factoring easier. These include using the difference of squares formula, recognizing patterns such as the difference of cubes, and practicing with different types of trinomial factoring problems.
  • Precalculus Mathematics Homework Help
33K
