Young Double Slit experiment, single photons
5 replies · 4K views · last reply
Mukilab
Hello, I was wondering if I could get any help with the following question/thing:
Why does a stream of photons (let's say that one is fired every 3 seconds) at a double slit as shown in Young's double slit experiment create an interference pattern although there is no interference because the photons are being fired with intervals, and they are already absorbed/something like that onto the photographic plate before the next photon is fired?
The interference effect is primarily from self-interference. The photon acts as a wave in this setup.
How can a wave interfere with itself?
That is exactly what waves do. Sound waves, water waves, any kind of waves. Did you ever see a ripple tank demonstration of this experiment? It clearly shows a wave interfering with itself.
Exactly Bill, I always find a picture paints a thousand words in this case.
http://www.upscale.utoronto.ca/PVB/Harrison/DoubleSlit/DoubleSlit.html
Diagram of a Young double-slit setup: circular concentric wave rings spread from the left and pass through two slits labelled 1 and 2 in a vertical barrier, with a detector on the right.
Diagram of a double-slit setup: concentric circular wave fronts spread from a source on the left, pass a barrier with two slits labelled 1 and 2, and produce a fringe pattern on a screen at right.
Diagram of a double-slit setup: concentric circular wavefronts spread from a source on the left, pass through two slits labelled 1 and 2 in a barrier, and a blue intensity curve with peaks is plotted on the right.
Note that after the wave passes through the two slits it will produce interference fringes with itself. It's even easier to show with an actual water tank where you can actually see a wave front interfere with itself after it passes through the slits. Although make sure you understand that water waves and energy waves are merely an analogy not an exact representation of physical fact. It's even more interesting that we actually have no idea what the wave really looks like but that is a whole 'nother issue, we can at least inductively assume from its behaviour it is a wave. :smile:
  • Diagram of a double-slit setup: concentric circular wave fronts spread from a source on the left toward a barrier with two slits labelled 1 and 2, with a detector shown beyond the barrier.
  • Diagram of a double-slit setup: concentric circular wave fronts spread from a source on the left, pass a barrier with two slits labelled 1 and 2, and produce an interference pattern on a screen on the right.
Diagram of a double-slit setup: concentric circular wavefronts spread from a source on the left toward a barrier with two slits labelled 1 and 2, and a yellow detector labelled Detector on the right.
Diagram of a double-slit setup: a wave from a point source spreads through a vertical barrier with two slits, labelled 1 and 2, and a green intensity curve appears on a detection screen at right with a black arrow pointing right.
Diagram of a double-slit setup: circular wavefronts spread from a source on the left through two slits labelled 1 and 2, with a blue interference intensity pattern plotted to the right.
Thanks, this helped me out a lot
