Can I Create a Focussed Electron Beam at Home with Household Items?
The Young's double slit experiment can be conducted at home using simple materials like smoked glass and razors to create slits. A monochromatic light source, such as an LED, is recommended for optimal results. While photons can be used in this experiment, generating a focused electron beam from household items is not feasible. The experiment demonstrates wave-particle duality effectively with accessible resources. Overall, it is possible to replicate the double slit experiment at home, but electron beam generation remains impractical.
kravi
Hi all,
Is it possible to do the Young's double slit experiment at home? A related question: Can I generate a focussed electron beam from house hold items?
Thanks
Ravi
kravi said:
Hi all,
yes. I think the simplest is to smoke a piece of glass over a candle flame. Using two straight edged razors held between fingers, use a ruler and mark two fine parallel lines gently on the smoked glass. Be careful your straight edge doesn't scuff the blacking. Make a similar, single, straight line on another piece of glass as the source of light. Mount everything in a shoe box or something being careful not to smudge the coating. Illuminate the single slit and see what you get coming out of the two slits projected onto an index card. Something like a an LED (not a white LED) would be a good source of monochromatic light to give you good bands on the other side of the double slit.
kravi said:
Hi all,
Thanks
Ravi
You cannot do it with electrons, but you can do it with photons. This works for all subatomic particles, however some create more noticeable waves than others.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
