moenste
- 711
- 12
1. The distance between the 1st bright fringle and the 21st bright fringe in a Young's double slit arrangement was found to be 2.7 mm. The slit separation was 1 mm and the distance from the slits to the plane of the fringes was 25 cm. What was the wavelength of the light?
Answer: 5.4 * 10-7 m
2. In a Young's double-slit experiment a total of 23 bright fringes occupying a distance of 3.9 mm were visible in the traveling microscope. The microscope was focused on a plane which was 31 cm from the double slit and the wavelength of the light being used was 5.5 * 10 -7 m. What was the separation of the double slit?
Answer: 0.96 mm (not 1.0 mm)
y = (λD) / a
1. a. Everything in m.
b. y = 2.7 * 10-3 / 20 fringes = 1.35 * 10-4 m.
c. λ = (y a) / D = ((1.35 * 10-4) *10-3) / 0.25 = 5.4 * 10-7 m.
2. a. Everything in m.
b. y = 3.9 * 10-3 / 22 fringes = 1.77 * 10-4 m.
c. a = (λD) / y = ((5.5 * 10-7) * 0.31) / (1.77 * 10-4) = 9.62 * 10-4 m or 0.96 mm.
Question: why do I need to decrease the number of fringles by 1 to get the right answer? If I use the given 21 and 23 numbers I get wrong answers. And in a different book which has "Five fringes were found to occupy a distance of 4 mm on the screen" the solution method is: "five fringes occupy 4 mm. So the fringe separation is 4 / 5 = 0.8 mm".
Any help please?
