Z/A in the Chandrasekhar formula
  • Thread starter Thread starter marcus
    Formula
The discussion focuses on the Chandrasekhar formula, which determines the maximum mass a white dwarf can have before collapsing under gravity, supported by electron degeneracy pressure. The term (Z/A)² in the formula represents the ratio of electrons to atomic weight, indicating how electron-rich an atom is and its ability to resist collapse. The formula is expressed as 0.20 (Z/A)² (hc/Gmprot²)³/2, relating mass to the proton mass. In natural units, it simplifies to pi (Z/A)² Λprot², with Λprot being the Compton wavelength of the proton. The discussion highlights the significance of this formula in understanding stellar remnants and their stability.
marcus
Homework Helper
Dearly Missed
A white dwarf---a cooling remnant of a star, no longer fusing---is protected from collapse by the pauli exclusion principle which says that no two electrons can occupy the same state (position and momentum). So crowding electrons together forces them to compensate by having high momenta and a pressure arises called "electron degeneracy pressure" which would exist even if the temperature were zero.
Chandrasekhar discovered a formula for the largest mass which can support itself against gravitational collapse by the pressure of its electrons.
this formula has a term (Z/A)2
how to understand it? well for a given atom Z is the number of electrons! and A is the atomic weight. So Z/A gives a good idea of
how electron-rich it is and how well it will resist collapse. In effect it is an "electrons per weight" number, giving a notion of "pressure per weight" as well.
That's all I have to say about it for now. I tried to understand the formula better today. If anyone has some insight or wants to try to explain it go ahead. Its interesting. The formula is:
0.20 (Z/A)2 (hc/Gmprot2)3/2
which is a pure number expressing the mass as a multiple of the proton mass mprot
In other words, if you want a complete expression for the mass you multiply the number times mprot and get
0.20 (Z/A)2 (hc/Gmprot2)3/2 mprot
That's verbatim from Frank Shu, I use a version rewritten using hbar in place of h.
Astronomy news on Phys.org
There is an important length called the (angular format) Compton wavelength of the proton
Λprot
and in natural units (c=G=hbar=1) it is simply the
reciprocal of the mass.
the mass of the proton happens to be 1/13E18 and so
Λprot = 13E18
In natural units the Chandrasekhar limit is expressed not in proton masses but in Planck masses and the previous formula
essentially simplifies to
pi (Z/A)2 Λprot2
it gives 1.3E38 for the case Z/A=1/2
If you prefer replace the lamba by the reciprocal of the proton mass, it doesn't make any numerical difference
pi (Z/A)2 (13E18)2
One solar mass is 0.93E38 in natural units, so if you like to express things in solar masses you can work out what 1.3E38 is.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
