Zero Point Energy and Bose Einstein Condensates
The discussion centers on the relationship between Zero Point Energy (ZPE) and Bose-Einstein Condensates (BEC) in the context of quantum mechanics, specifically addressing the limitations of the Schrödinger equation (SEqs) and Density Functional Theory (DFT). Participants clarify that while ZPE represents the minimum energy at absolute zero, it is not inherently included in the ground state energy calculations derived from SEqs. Furthermore, it is established that a lattice of rubidium atoms cannot form a BEC, as the conditions for BEC formation are incompatible with lattice structures. Modern computational tools like VASP can calculate ZPE, but the accuracy of DFT for simulating BECs is questioned due to its semi-empirical nature.
  • Understanding of Quantum Mechanics and the Schrödinger Equation
  • Familiarity with Density Functional Theory (DFT) and its applications
  • Knowledge of Zero Point Energy (ZPE) and its implications in quantum systems
  • Concepts of Bose-Einstein Condensation and its requirements
  • Research the limitations of Density Functional Theory (DFT) in simulating quantum systems
  • Explore the calculation of Zero Point Energy (ZPE) using VASP software
  • Investigate the conditions necessary for the formation of Bose-Einstein Condensates (BEC)
  • Study the Born-Oppenheimer approximation and its relevance to vibrational energy calculations
Physicists, quantum chemists, and researchers interested in quantum mechanics, particularly those focusing on the properties of Bose-Einstein Condensates and the implications of Zero Point Energy in computational simulations.
askhetan
They say ZPE is the energy of the system at 0 K due to vibrations and even though the Schroedinger equation gives us the ground state minimum energy of the system (lets say by DFT/HF/QMC whatever), this energy is a little higher than that.
My first question is, because I have learned that SEqs is the most basic equation of QM, why are the atomic vibrations at 0 K not an out come of the SEqs. Because in reality now our ground state is redefined. If the system can NEVER have energy less than ZPE then isn't it the ground state energy. I know it might be very difficult to calculate, but apart from the electronic ground state shouldn't ZPE be also included in the ground state?? Or is this energy out of the purview of SEqns
My second question is - if i am simulating (using DFT or other ab-initio method) the lattice system which has total integer spin (like let's say a collection of rubidium atoms) - then does my simulation actually give me a BOSE EINSTEIN condensate..??
When they say so they most probably refer to the solution of the electronic Schroedinger equation in Born Oppenheimer approximation.
The vibrational energy has (and can) be calculated in a second step, so there is no problem with modern programs to calculate the ground state energy including the ZPE.
To your second question: Forming a lattice and BEC exclude one another. So a lattice of Rb atoms cannot form a BEC.
Thanks DrDu! I get it now. Programs like VASP can indeed calculate the ZPE. I still think though that it doesn't make much sense to use the ground state energy values not taking into account ZPE in the ground state energy, because including it gives us a better result.
As for your answer to the second question:
Of course BEC is not a lattice. I will try to reframe my question (which is inspired from a documentary which told that one of the first systems which was made into a BEC composed of rubidium atoms). Supposing I simply calculate for a given number of rubidium atoms using DFT at 0 K - why should the system not be a BEC? The only requirements for BEC are bosonic systems and extremely low temperatures which are both satisfied in this case I guess
There are several problems with this:
A) DFT is a semi-empirical proceedure and functionals are neither designed nor sufficiently accurate for this kind of calculations.
B) You would have to include the confining magnetic and electric potentials.
C) That would be quite a formidable task for several thousand Rb atoms.
D) It does not make much sense. You can obtain all the relevant parameters, like the scattering lengths from accurate calculations done on one or two atoms.
Thanks!
  • · Replies 36 ·
9K
