| Thread Closed |
[Problem]: Magnitude/direction of magnetic force, electric force and the net force. |
Share Thread | Thread Tools |
| Nov24-09, 03:01 PM | #1 |
1. The problem statement, all variables and given/known data
A magnet produces a 0.40 T field between its poles, directed horizontally to the east. A dust particle with charge q = -8.0×10^-18 C is moving vertically downwards with a speed of 0.30 cm/s in this field. Whilst it is in the magnetic field, the dust particle is also in an electric field of strength 1.00×10^-2 V/m pointing to the north. (a) What is the magnitude and direction of the magnetic force on the dust particle? (b) What is the magnitude and direction of the electric force on the dust particle? (c) What is the magnitude of the net force on the dust particle? 2. Relevant equations F=|q|vB F=(k|q1q2|) / r^2 B=E/V 3. The attempt at a solution a) Magnitude: F=|q|vB = (-8 x 10^-18 C)(-0.003 m/s)(0.4 T) = 9.6 x 10^-21 N Direction: Since the velocity is south and the force must be perpendicular to the velocity, the force must lie in a plane perpendicular to the north/south axis. b) I know it has to do with "1.00 x 10^-2 V/m" but all I could do with it was: Magnitude: B=E/V --> (1.00 x 10^-2 V/m) / (0.003 m/s) = 3.3(repeating) T Direction: North c) Would the net force be the sum of answers "a" and "b" or would it be: Net force = sqrt(a^2 + b^2) a: being the force in a) b: being the force in b) Thank-you. |
| Nov25-09, 02:38 AM | #2 |
Recognitions:
Hi quik,
| Nov25-09, 02:56 PM | #3 |
Hello alphysicist, thanks for replying.
+z axis = out of screen +x axis = B -y axis = v But if the force is either North or South, since the velocity is going south, wouldn't it be north? Thanks again |
| Nov25-09, 07:13 PM | #4 |
Recognitions:
| Nov27-09, 01:10 AM | #5 |
Direction: North Direction: South Magnitude: 7.04 x 10^-20 N Direction: South |
| Nov27-09, 12:50 PM | #6 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: [Problem]: Magnitude/direction of magnetic force, electric force and the net force.
| Thread | Forum | Replies | ||
| Magnitude and Direction Force Problem | Introductory Physics Homework | 13 | ||
| Lorentz Force Law to determine the magnitude and direction of an electric field | Introductory Physics Homework | 10 | ||
| magnitude and direction of electric force (file attached) | Introductory Physics Homework | 6 | ||
| magnitude of an electric force problem with vectors | Introductory Physics Homework | 3 | ||
| Magnetic Force to balance out Electric Force | Introductory Physics Homework | 2 | ||
