Thread Closed
most force/strength used in the same time frame
Share Thread Thread Tools
Nov24-11, 07:54 PM   #18
Quote by Zula110100100 View Post
The average is the same, but that is not the end of the story.
I guess every post I should include: This is not likely to be how lifting weights actually works, at all.
But...lets take for example, the lowering of 100kg, over 1m, starting at the top, and at rest.
If I apply no force for .5m then it will gain a KE of mgh 100(-9.8).5 = -490J
The instantaneous velocity will be Ke = .5mv2
sqrt(490*2/m) = -3.13m/s
avg velocity -1.56
s/v = t
.5/1.5 = .319 seconds = t
In order to stop it in .5m requires an equal change in KE over the same distance, so yes, it is also 490J, and the acceleration is 9.8, showing a NET force of 980N, however, to achieve this net force requires force applied to be (980+980) = 1960N, times another .319seconds equals an applied force of
Gravity impulse = -626N*s
Force-applied impulse = 626N*s
Net Impulse = 0;
Total time: .638s
Total dist: 1m
Δv = 0
Now the same setup but it will drop freely for .75,
However in the faster rep, it’s not dropping freely, I am lowering it under control, as if it dropped freely, it would drop far faster.
in that situation it gets 745J, this time we must counter than in .25m, so the required net force over that .25m is 2940N
at the .75mark we would have an instantaneous velocity of 3.86m/s, that is a momentum of 386N*m/s, Δp = Ft so the time to come to a stop is Δp/F = 386/2940 = .13seconds
The time to traverse the .75 and get to that speed is Δp/g = 386/980 = .39
so:
Gravity impulse = 509.6N*s
Force-applied impulse: = 509.6N*s
Net impulse: 0
Total time: .52s
Total dist: 1m
Δv = 0
So this is the same weight, time difference is .118s (A: .638s, B:.52s), now the force-applied impulse does equal the gravity impulse, but are not equal with each other, the slower rep(A) does take more Newton*seconds, now, I agree, the wording is bad, and Wayne, you must realize that by applying that many newtons, for a seconds, you don't divide it like meters/seconds, newtons are a force that can be applied over some seconds to give a multiplied result of Newton*seconds, this is called an impulse and is responsible for a change in momentum.
Hmm sorry about this, but I think it’s best to ask questions I think if I don’t get something.
So the slow eccentric seemed to take .638s to be lowered 1m and the force/strength used was 626N ??? But if we are talking of slow rep, it was lowered in 3 seconds.
And the fast eccentric .52s that basically .5 of a second, to be lowered 1m and the force/strength used was 509.6 ??? But if we are talking of fast reps, it was lowered in .5 of a second, yes, but lowered 6 times in all, thus we have to add the force/strengths up, as it takes more force/strength to lower something 6 times to 1 time.
I believe the point being made by Douglis is that in order to have 0 momentum on the top and bottom the sum of the impulses must be 0,
Not sure the point here to be honest.
However at both transitions the zero movement is so small of a time, do we need to bother with this ??? As at that time, which would be a Milly of a second, would have no force/strengths ???
otherwise it would still have momentum in one direction or another,
But we do have movements in both directions, its only the grip of the hands and the muscles forces/strengths that stops this on both transitions ???
however, the slower you go down, the greater the time that gravity is acting on the weight, this creates a larger impulse from gravity, in order to get that sum of 0, this in turn, requires a greater impulse of force-applied, so going slower does require more FORCE be APPLIED each SECOND. So that is showing that on the way down(including deceleration time) a slower lowering requires a greater force-applied impulse.
Hmm, I can’t really see that, as of below, but if you’re saying the 3 second lowering to the .5 of a second lowering uses more force/strength, than yes this must be so, as the slow is using force/strength for 2.5 seconds longer.
But what if we added all the 6 lower rings of the faster reps each at .5 of a second ???
I do not agree with this, on the second upward rep, you would have once again brought it to a stop at the instant before the rep begins, so it should be equal. The extra force to stop it goes into the previous downward rep. this really depends on when you view a rep beginning but I feel that is the most accurate is that the next upward rep begins once you are at the bottom of the range, which we agreed in this system you have decelerated by the time you get there.
Hmm, I see your point, however when lifting at say .5/.5 you do the transition so fast from negative to positive, that the faster you do it the harder it is, and it’s done very fast. Lets exaggerate, or put up a scenario, let’s say I lift 80% from a still start, on the bench press, think we all know what the bench press in, but the next time, the person lifts it for me, and then I take my arms away, and lover them, then the person drops the weight, and I catch it three quarters of the way down and try the press it back up, do we all agree that the drop and press would be far harder, than the still start ??? Actually that drop might even put about 40% more weight on the bar. As that’s more what happens, when repping the weight up and down, you immediately go from lowering the weight fast under control, to lifting it back up before it gone down fully.
If you hold a heavy weight, best if it’s at least 20 pounds, then lift it and lower quite fast, you will see that the moment you stop it the reading goes up.
Also, if I am doing squats, say I am doing reps with 300 pounds, its far harder to get the weight moving back up on the concentric, if you lower it very fast, as it gathers speed, thus it appears to be heaver. So if I was doing 12 reps at a slow eccentric, say 1 second, and a fast as possible concentric, I would be able to do the 12 reps, BUT if I lowered the weight much faster, it would make the exercise far harder, and I might only get 6 reps
This is wording too really, I would almost define a force as a factor of gathering, a net force defines: 1: The rate at which energy is gathered(or negatively gathered, lost) over distance, 2: The rate at which momentum is gathered(or negatively gathered, lost) over time
For example, in gravity a 100kg weight would gather kinetic energy at a rate of 980N/m
It seems the same would be true for the way up, so slower reps = MORE force-applied impulse, but also MORE gravity impulse balancing it out, so less work being done since less NET force over the same distance
Going to have to read that part over a few times. However if you’re saying what I just said above, that the 3/3 = 1m, has to use more force/strength than the .5/.5 = 1m, then yes, however the faster reps at .5/.5 are done 6 times, to be done in the say time frame, that’s 6 seconds like the 1 slow rep = 6 seconds.
One thing no one seems to answer, how can you move the same weight more distance in the same time frame without using more force/strength ??? It’s impossible. As in my fast rep moving the weight 1m in .5 of a second, the slow have only moved its weight 166mm.
And if we take the 6 reps at .5/.5 moving the weight 1m up and 1m down 6 times in 6 seconds, its moved the weight 12m to the slow rep of moving the weight 1m up and 1m down 1 time in 6 seconds, its moving the weight only 2m.
Also my EMG reading state that there is more force/strength/more/muscle/activity in the faster reps ???
. First I did right leg, leg extension, quite fast, something like .5/.5
Then I did left leg, leg extension, quite slow, something like 3/3.
Both obviously were to the set time, which was 25 seconds.
Fast = average work = 295 iV
Slow = average work = 177 iV
The fast was 118 IV or 61% higher than the slow, as of MORE average/total force/strength is used.
So what have the few that said other have to say about this ???
Also you fail faster in the faster reps, in my opinion that would say you are using more force/strength faster ???
http://www.youtube.com/user/wayneroc.../0/sbRVQ_nmhpw
Thx for your time and help all.
Wayne
Nov24-11, 10:57 PM   #19
No, in my example the height was 1m for both, slow and fast, I did not work it out for slow, short distance.
"I believe the point being made by Douglis is that in order to have 0 momentum on the top and bottom the sum of the impulses must be 0,"
The point here is that if it goes to 0 at all, then all of the energy put into it was taken back out at the other end, that is the only way to get it to 0 at the point you want
I don't lift a lot of weights, but I was figuring you do not push them up so fast that you stop them with the other side of your hands wouldn't that be horrible jerk on your tendons? like, if you did an open-hand benchpress, would it fly out over your hands, or just raise up and stop without leaving your hand?
Alright, lets go with 80lbs, thats about 36kg, force of gravity is 352.8N, gravities impulse over 3 seconds is 352.8N * 3s = 1058.4N*s if it stops at the 1m mark at 3seconds, then you MUST have applied 1058.4N*s over that time period, it could have been 1058.3N for 1 second or 529.2N for 2 seconds, either way you applied 1058.4N*s of impulse.
The same is true on the way up, whatever impulse was applied must have been equaled by gravity, or else it would be in motion at the top, and we would not be looking at a 3/3 1m model, we would have different numbers.
So for the 1 rep, over 6 seconds, the force applied must have been equal to gravities impulse over that 6 seconds, or else we would still be in motion and not on the model.
352.8*6s = 2116.8N*s of impulse
for a .5/.5 1m, 6 reps, we are looking at 352.8*.5 = 176.4N*s impulse 1 way, 352.8N8s impulse round trip, so 6 over those is equal to the previous answer of 2116.8N*s, since we still have 6 seconds of gravity acting on 36kg of mass. and as per the models, we still have a beginning and ending momentum of 0.
change in momentum = force * time
This is because momentum and force are really just velocity and acceleration, respectively, with mass taken into consideration
momentum = mv
force = ma
anyone would agree that v = at, so momentum = force * t is really the same thing.
In my opinion it is because you apply less force against gravity, and allow gravity to pull it more quickly
I would REALLY like to stress that your body is a bunch of levers and your appendages bend and can feel different at different angles, and it might take more energy at different angles, also, the slower you go, the more you will be exercising balancing muscles, we cannot really take that into account without know a LOT about the physics of your body, that is why I say the actual way lifting weight works is pretty much unanswerable, not unanswerable, but I sure don't know enough of what goes on in your body.
The answer I am helping you with are for the FORCES, it would be correct for the forces measured on a force-plate, I think, but it has no DIRECT link to how tired you get, or how much muscle activity is going on, there are alot of other things at play here, This is a simplification to certain aspects, in this case, the "Force applied" to the weights.
It is very well possible that more signal is required to make your muscle apply more force over a shorter time, I don't know how muscles work that well, I would take that specific question to a biology forum, The fact of the matter though is that whatever is required to get your body apply that force, the result is an equal amount of acceleration(force)*time
Nov25-11, 02:27 AM   #20
Zula...I admire your patience!Nice explanation anyway.I don't have anything to add.
God knows how many times the above has been explained to Wayne.
So Wayne...you got your answer once again.I'll wait for your next thread after a few weeks asking the same thing.
Nov25-11, 08:17 AM   #21
Hi everyone,
No time to read anything in work.
Here is a study/test showing the there was more force/strength in the faster lifts as what I am saying, but D. says they are leaving something out, but he can’t or will not explain to me what, in scientific terms or layman’s. Could anyone here please say whets been left out if anything.
http://docs.google.com/viewer?a=v&q=...ObsxJUbHpDqdXQ
If you note, the graph, table 2, normal 170kg produced 17.9N force/strength to the slow 6.2N. That’s about 180% MORE force/strength, and in less time, the slow force/strength was calculated in 10.9 seconds, and the fast in 2.8 seconds.
Imagine the slow person had 6.2N of force/strength or should I say that ammount of tension on his muscles for 10.9 seconds, the fast person had 17.9N of force/strength or should I say that ammount of tension on his muscles for 2.8 seconds.
But if the fast person had done the fast for the same amount of time, he would have had 17.9 of force/strength used by his muscles for 10.9 seconds. This as I said is a huge difference, 180% more force/strength used by the muscles, or should I say tension on the muscles from the force/strength used, in the same time frame.
Wayne
Nov25-11, 09:11 AM   #22
Recognitions:
Gold Membership Gold Member
@Wayne
Why do you keep using the two terms force and strength together? They just don't mean the same thing. 'Force' (an active word) is something that changes shape of an object or produces acceleration. 'Strength' (a passive word) refers to how an object will deform when a force is applied. If you really want a scientific answer then you could at least use scientific words appropriately in your questions.
Nov25-11, 09:42 AM   #23
Quote by waynexk8 View Post
Wayne
No...read what they write.The 17.9N and 6.2N are the mean propulsive forces....which as they explain represent the additional to the load force required for the positive acceleration.
For the negative acceleration the propulsive force takes negative values which are not measured in the study.
The average propulsive force is zero and the force equal with the weight regardless the speed.
Nov25-11, 12:07 PM   #24
Equation 3 from that source points out that a linear impulse is equal to change in linear acceleration
If we take an force of 6.2N over 10.9 seconds, that is an impulse of 67.58N*s
This means we must see a change in momentum of 67.58kg*m/s The weight presumably started at a velocity of 0, so this means it is left with a velocity of .4m/s, thus, it has not yet stopped moving, if you stop applying force, it will take gravity another .04s to stop it, and during that time there is a negative propulsive force, an applied force less than the force required to hold the object up.
So in my opinion the data is not good, because they did not wait for it to stop to take their readings.
If you take 1672.2N(the applied force required to get a propulsive force of 6.2N) * 10.9+ 0N*.04s = 1672.2 and then divide that by the total time 10.94 = 1666.0859N avg which is really close to the 1666N that were required to hold it up.
For the faster rep, we have an avg propulsive force of 45.3N * 2.8s = 126.8N*s, so we know it is left with a velocity of .75m/s which would take gravity .076s to decelerate, so again, add the 45.3 to 1666 = 1711.3*2.8s = 4791.64N*s from the force applied
+0n*.076s =4791.64/(2.8+.076) = 1666.078 once again really close to the force required to hold it still in the first place.
So overall, sure, it is more force to get the same weight going faster, anyone will agree there, the problem is that unless you apply a force to pull the weight down toward you before it stop moving up, then comparing the force for the whole cycle should be the same
in other words, if you apply more than required to hold it up, and then never less than required to hold it up, it will keep moving up, since that is not the case there is more going on than listed in that expiriment
Nov25-11, 12:38 PM   #25
@sophiecentaur
In layman's terms, strength and force are very similar, a strong person can supply more force than a weak person, a force with a large magnitude is a strong force, a force with a small magnitude is a weak force, so strength is like the magnitude of force in a way
-degree of intensity or concentration
I agree with the problem in wording it "used more strength/force" because it's not something you use up per se
I guess it is that you think if he comes here to ask a question he should have it in the correct format for physics, and he assumes he can use terms how HE uses them and we being the ones knowledgeable in physics will know the physics terms to work out the problem he is outlining. It depends on what you feel the point of this forum is.
Nov25-11, 02:36 PM   #26
Recognitions:
So how would we describe the ability of a structure to resist a force if we've already used the word strength?
It's surely not too demanding to use the right (common) words if you want serious help about a scientific topic. Unless it's just a trivial query- which it clearly is not.
Nov25-11, 03:26 PM   #27
Doesn't really matter, unless you expect everyone on this forum to be able to ask questions using appropriate physics terms when they may be coming because they are not very familiar with physics. I believe anyone can infer that he means strength as a measure of your overall ability to apply force, so the more of that ability you use, the more strength you use. It's what is meant that counts, in my opinion.
Nov25-11, 04:24 PM   #28
Of course there's more going on than listed.The subjects obviously applied less force than required to hold the weight up at the deceleration phase that occured in order to prevent the weight fly in the air.With the method they use the negative values of the propulsive force can not be measured or they chose not to record them.
The true mean propulsive force is 0 because the net delta V is zero. The average force is always equal with the load and...to use Wayne's terms...the "total applied force" is equal with gravity's impulse over the duration of the rep(force*time).
So to summarize...either you lift 100N once with 3/3 or 6 times with .5/.5 the total applied force is 600N*s in both cases.
Nov25-11, 05:17 PM   #29
Recognitions:
I think you are missing something important here. When an 'uninformed' person reads a thread, they may not distinguish what's good and what's bad information. Would you really want a School student, at an elementary level, to go away thinking that strength is the same as force by taking one of Wayne's posts as gospel? One of the difficulties that the non-Scientist has is that the commonly te accepted meaning of many words conflicts with how they are used, formally, in Science. This leads to any number of misunderstandings.
@Wayne - I'm not just 'picking on you' and I'm sure that you have a genuine wish to get something out of this thread. Your terminology is just one example of what I'm talking about. There are far far worse things to be seen elsewhere.
Only today, the moderators have actually pointed out the necessity of 'reporting' contributions that are potentially harmful to understanding. We owe it to people to keep a high standard where possible if we are to maintain our present level credibility. It's ok to be laid back about some things when you know your audience but it's really not fair to people if we don't keep our technical house in order. What is this forum for, when you get down to it?
Nov25-11, 06:21 PM   #30
Quote by sophiecentaur View Post
I have connection problems, I am online with a dongo, it’s very slow, so can’t say much.
Sorry about the wording sophiecentaur, will try better, buts it’s hard when I have not been shown. And I am genuine and want to learn.
One thing is no one will answer me is the distance, force problem I am having, could you ??? If impossible to lift 80% in .5 of a second to 1m, the time could be less, but I am sure I could lift that in the time, will try it on video>
1,
We both have a 100 pounds of maximum strength that we can bench press. We you 80% 80 pounds, I move the weight 1000mm in .5 of a second, I will be accelerating this weight for 60% for the ROM, {range of motion} of for the concentric rep, you will be moving the same weight in .5 of a second for only 166mm.
Question,
If I have moved the weight more distance in the same time frame, does that not that mean that I have used more force ??? {force and strength are the same I would have thought, but let’s just go for force now} As even if you just count my acceleration its 600mm, that far moiré distance than the slow.
2,
I bench press the same weight same distance of 80% {and this weight of 80% is important, as my maximum is only 20% more than my maximum} I lift at .5/.5 for 6 reps = 6 seconds covering a distance of 12m. The slow lifts at 3/3 for 1 rep = 6 seconds, covering a distance of only 2m.
Question, basically the same as the above.
As a force that causes an object with a mass of 1 kg to accelerate at 1 m/s is equivalent to 1 Newton, if you move it futher in the same time from you have to use more force, N’s.
Wayne
Nov25-11, 06:42 PM   #31
As I said, big thx for your help and time. I do not have much time, so would like to ask you AND THE OTHERS before I answer the above, the question that I asked before, as I am having difficulty understanding the above without this added in.
If I lift 80% up to 1m from a still start, and then lift 80% up from when it is being lowered under control at .5 of a second down, the weight will gather acceleration/ movement thus appear to be heavier than it is. Meaning if you put the 80% on a scales on the standing start it wound register 80 pounds. However if you could immediately put the scales under the weight at 1m when it had dropped 1m in .5 of a second, it would register far far far more.
So it would take more force to lift the same weight up and down on the second moving rep, than to just move it up and down from a still start.
Also, is not power in mechanics, the combination of forces and movement ??? I thought power was the product of a force on an object and the object's velocity ??? As we all will agree that the fast uses more power, {even I can work that out with some simple equations} so if power is the of a force on an object and the object's velocity, does that not mean more force more power ???
Wayne
Nov25-11, 11:40 PM   #32
The process that causes it to register more is the "force-applied" impulse being shorter time, more force(higher reading), but this will still be equal to the impulse of gravity if you average in the time that no force was applied. Just before it is moving up again, it IS at a still start again. Any extra force applied to "get it going back up" from downward motion can be split between stopping it and starting again. The "stopping it part" is part of the downward rep.
Nov26-11, 05:15 AM   #33
@wayne
I am not sure how exactly your EMG machine works, but would you be able to test the muscle activity that results from holding a variety of weights at a variety of heights, holding it in place for a specified time? If so that would give you an idea of what a change in force-applied impulse gives in the EMG results.
Nov26-11, 08:01 AM   #34
@wayne
Again thx for your help. Yes I can do that. The dual EMG {Electromyography} is a machine that you put four pads on the muscles, and they read the eletrical activity in the muscles, more average evtivity would mean more force and strength used by the muscles. However I imagine you have done a little Google to see the basics of how it works.
Still on this dongo, and it very slow and does not hold a connection. This time I will copy and paste all and read in full and get back when my broadband is up and running fully. Wrote this before going online.
Douglas, you are telling me that a few people have worked this debate down on paper, and some say the forces are the same, first, I have put four electrical pads on my muscles that measure the muscle activity = muscles forces and strengths with a dual EMG, and in a real life experiment done several times in front of me, I have seen the reading that state there in more muscle activity in the faster reps every time. So do you not think that you have left something out of your equations maybe ??? Look, 40 + 40 x 0 + 1 = ??? I would say 81, as 40 + 40 = 80 X 0 = 80 + 1 = 81, but some say its 41 and some 1, just for fun could all please answer this, AS IT MIGHT HELP ME SEE IF I AM GOING WRONG HERE.
Thx all.
Wayne
Thread Closed
Thread Tools
Similar Threads for: most force/strength used in the same time frame
Thread Forum Replies
Time frame of the sun General Astronomy 4
time dilation b/c of Gravitaional field strength Special & General Relativity 3
Creating : one frame at a time Quantum Physics 8
strength of electrostatic force Introductory Physics Homework 3
Relation strength interaction and decay time High Energy, Nuclear, Particle Physics 1
