| New Reply |
Field Redefinition and EOM |
Share Thread |
| Nov28-12, 02:02 PM | #1 |
Hi,
I am given an interaction lagrangian piece as [tex] \mathcal{L}_1 = \frac{1}{2} g \phi \partial^\mu \phi \partial_\mu \phi [/tex] Now normally when I have an interaction lagrangian piece I turn the field's into variations with respect to the source [itex]\delta_J[/itex], and take variations of the free partition function to get feynman diagrams, however in this case the partials confuse me. Am I allowed to use the EOM at this stage to simplify the interaction term? Or can I preform the following operations [tex] \frac{1}{2}g \phi \partial^\mu \phi \partial_\mu \phi \rightarrow \frac{1}{2}g \Box (\delta_J)^3 [/tex] since typically the variation and the partial `commute'? EDIT: I realized I can integrate by parts, that maybe helps a little, but I am still almost in the same boat as before. After integration I get [tex] \mathcal{L}_1 = -\frac{1}{4}g \phi^2 \Box \phi [/tex] since the total derivative vanishes. Thanks, any help is appreciated. |
| Nov29-12, 01:41 PM | #2 |
No transformation necessary, each φ is represented by a line coming to the vertex, and for each ∂μ include as a factor the corresponding k-vector.
| Nov29-12, 02:34 PM | #3 |
Thanks a lot Bill.
So I would write something like [tex] \rightarrow \frac{i}{2}g(i k^\mu )(i k_{\mu}) = \frac{-i}{2}g k^\mu k_\mu [/tex] for the vertex factor in a diagram. Then for a field redefinition to the scalar lagrangian [tex] \mathcal{L}_0 = -\frac{1}{2}\partial^\mu \phi \partial_\mu \phi - \frac{1}{2}m^2 \phi^2 [/tex] of the form [tex] \phi \rightarrow \phi' = \phi +\lambda \phi^2 [/tex] I end up with something of the form [tex] \mathcal{L} = \mathcal{L}_0 -2\lambda \phi \partial^\mu \phi \partial_\mu \phi - 2 \lambda^2 \phi^2 \partial^\mu \phi \partial_\mu \phi -\lambda m^2 \phi^3 - \frac{1}{2}\lambda^2 m^2 \phi^4 [/tex] Then I have associated vertex factors of the form [tex] 2i\lambda k^2 \quad 2i \lambda^2 k^2 \quad -i \lambda m^2 \quad -\frac{i}{2}\lambda^2 m^2 [/tex] |
| Nov29-12, 04:23 PM | #4 |
Well if the interaction has three φ's, there's three k's also, with k1 + k2 + k3 = 0. So the factor in front of φ ∂μφ ∂μφ, instead of k2 wouldn't it have to look more like k1·k2?
| Nov29-12, 05:17 PM | #5 |
So the phi without a partial derivative is acting like a mediator; it takes away [itex]-(k_1 + k_2)[/itex] from the interaction vertex? However, the assignment of momentum labels is arbitrary, how can I let my convention decided which momenta are the ones I have as factors...?
| Nov30-12, 08:06 AM | #6 |
You'd have to include all three possibilities. And for the φ2 ∂μφ ∂μφ term there would be six!
| Nov30-12, 09:31 AM | #7 |
| Nov30-12, 12:13 PM | #8 |
So then using my expression for [itex]\mathcal{L}[/itex], I would have
[tex] (i \lambda) (2(k_1 k+k_2 k+k_1 k_2)-m^2) \quad \text{and}\quad (i \lambda^2)(2(k_1 k_2 + k_1 k_3 + k_1 k_4 + k_2 k_3 + k_2 k_4 + k_3 k_4)-\frac{1}{2}m^2). [/tex] as my vertex factors? Thanks for your guys help. |
| Dec1-12, 07:00 AM | #9 |
I am not getting why are you redefining the field by a transformation,Vertex factors are always sandwiched between free particle states.There you can use eqn of motion to elliminate some k's by on-shell condition(it will be an approximation)
| Dec1-12, 09:08 AM | #10 |
What if the vertex is just one part of a larger diagram. Then the lines coming to the vertex will be off-shell propagators.
| Dec2-12, 01:00 AM | #11 |
| New Reply |
Similar discussions for: Field Redefinition and EOM
| Thread | Forum | Replies | ||
| Can a time-varying magnetic field emulate the electric field of a point charge? | Classical Physics | 3 | ||
| Signs LQG has the right redefinition (or wrong?) | Beyond the Standard Model | 140 | ||
| similarities and differences between B-field, E-field and G-field | Introductory Physics Homework | 0 | ||
| total field, scatt field, incident field.... | Classical Physics | 0 | ||
| Redefinition of a scalar field | Advanced Physics Homework | 4 | ||
