crybllrd
- 120
A ladder of 25 feet long is leaning against the wall of a house. The base of the ladder is pulled away at 2 ft per second.
(a) How fast is the top of the ladder moving down the wall when the base is seven feet from the wall?
(b) Consider the triangle formed by the side of the house, ladder and ground. Find the rate at which the area of the triangle is changing when the ladder is 7 feet from the wall.
(c) Find the rate at which the angle between the ladder and wall is changing when the base of the ladder is 7 ft from the wall.
(a) x=7ft y= 24 (pythag thm) dx/dt=2ft/s dy/dt=?
[tex]x^{2}+y^{2}=25^{2}[/tex]
[tex]2x\frac{dx}{dt}+2y\frac{dy}{dt}=0[/tex]
[tex]\frac{dy}{dt}=\frac{2x\frac{dx}{dt}}{-2y}[/tex]
[tex]\frac{dy}{dt}=\frac{-7}{12}ft/s[/tex]
I feel like part A is correct. Part B is where I'm stuck:
(b)
[tex]A=\frac{1}{2}xy[/tex]
[tex]\frac{dA}{dt}=\frac{1}{2}\frac{dx}{dt}\bullet\frac{dy}{dt}[/tex]
Here I was going to plug in dx/dt and dy/dt from part (a) but it gives me the same solution as part (a). What should I do?
(c) Not sure about (c) either, assuming I need to start with sine theta, but I want to get on top of part B first.
