Finding out if 2003^2004 - 2005 is divisible by 10?
  • Thread starter Virtate
In summary, the conversation discusses two different problems involving divisibility by 10 and 33. The first problem involves finding out if 2003^2004 - 2005 is divisible by 10, and the second problem involves determining if 3^102 * 7^29 is divisible by 33. The conversation also mentions that the problems are related to a homework assignment. One person provides a hint for solving the first problem, while another person explains the concept of divisibility by 33. The conversation ends with a note that the threads have been moved to the appropriate homework section.
Virtate
Hello,
I was wondering, how does one go finding out if 2003^2004 - 2005 is divisible by 10? Or that 3^102 * 7^29 is divisible by 33?
If someone could help me, I would really appreciate it.
Thank You.
We do help people with homework here, but you have to show how you started and where you got stuck.
I only got as far as 2003 = 3 (mod 10), and I have no idea where to go from there. I think I'm headed in the wrong direction... If someone could give me a few pointers, that would be great.
OK, in order for 2003^2004-2005 to be divisible by 10, it has to end in zero. That means that 2003^2004 has to end with 5 (because when you subtract 2005, you'll get a zero in the ones place). Now you should be able to tell pretty straighforwardly if 2003^2004 ends with 5.
As for the other one, any number that is divisible by 33 must be divisible by both 3 and 11. Since you were given the prime factorization of the other number, you should be able to tell just by looking whether it is divisible by 33.
Incidentally, it was me who moved your thread to the K-12 HW section. I can see from your second thread that this is probably a College course, so I've moved both this thread and your other one to College HW.
Any and all homework questions go to this area, not in the Math section.
Thanks Tom!
1. How do you find out if a number is divisible by 10?
A number is divisible by 10 if it ends in 0 or if the last digit is 0.
2. What is the process for finding out if 2003^2004 - 2005 is divisible by 10?
The process involves evaluating the expression 2003^2004 - 2005 and checking if the result is divisible by 10.
3. Why is it important to check if a number is divisible by 10?
Checking if a number is divisible by 10 is important because it is a basic divisibility rule that can help in simplifying calculations and determining if a number is evenly divisible by 10 without actually performing the division.
4. Can you explain the significance of the number 2003^2004 - 2005 in this question?
The number 2003^2004 - 2005 is significant because it is the expression being evaluated to determine if it is divisible by 10. It is also a large number that requires the use of mathematical tools and techniques to evaluate it accurately.
5. What happens if 2003^2004 - 2005 is not divisible by 10?
If the result of 2003^2004 - 2005 is not divisible by 10, it means that the expression is not evenly divisible by 10 and there may be a remainder when dividing by 10. In this case, the expression is not divisible by 10.
  • Math POTW for Secondary and High School Students
