Prove using the definition of a limit, Please help
In summary: E^2 \sqrt{n} + E} < \frac{1}{2E^2 \sqrt{n}} < EN = \frac{E}{2E^2 - E^3/2} where E < 1. If E > 1, then it would be: N = \frac{E}{2E^2 + E^3/2}. So this is what I got last night. I'm wondering if this is correct. It's the only thing that I could get to work out. Thank you both for your help! It means a lot to me.
silvermane
Prove using the definition of a limit, Please help! :)
Prove using only the definition of a limit, that the sequence:
[tex]\frac{n}{(n+1)^1/2}[/tex] - [tex]\frac{n}{(n+2)^1/2}[/tex] converges.
Let E>0 and choose a special N = something*E that whenever n>N our difference of limits is less than E...
I know that the limit is 0, but I'm having trouble finding the special N. The algebra for this is horrible and I've spent a long while working on it. Please help. It will be greatly appreciated.
hint #1
show that
[tex]\sqrt{\frac{n}{n+1}}-\sqrt{\frac{n}{n+2}}<\sqrt{\frac{n}{n+1}-\frac{n}{n+2}}[/tex]
and use this fact to simplify what needs to be less than E. That is, find N such
[tex]\sqrt{\frac{n}{n+1}-\frac{n}{n+2}}[/tex] is less than E for all n > N and you've got it.
But I don't have a square root in the numerator; it's just in the denominator. I'm slightly confused, but will keep looking at it - in case it was me. :(
Here's what I did:
I have that my above sequence is equal to
[tex]\frac{3n^2}{n^2+3n+2}[/tex] < [tex]\frac{3n^2}{n^2+3n}[/tex] < E
and my N = [tex]\frac{2E}{3-E}[/tex]
Sorry. i misread it.
Here's what I did:
So you've got it now?
Well, I want to make sure that what I'm doing is correct. I've gone to my professor's office, and he wasn't very helpful to me. (there's a language barrier)
Either way, does my N make sense and is mathematically correct?
I wanted to get an N without squaring it as well, so I don't think what I've done above is allowed to be done.
Thank you so much for your help so far :)
Well, actually no. How did you get
I squared everything and then simplified. I've come to realize however, that it's not something I shouldn't have done, but I wasn't thinking clearly at the time. I'm stuck when it comes down to the algebra: I know the limit is 0, so I just need to simplify my expression... I can then find a comparison to get a good N for my proof. I'm starting to become very frustrated with this problem. :(So far, I have this:
= [tex]\frac{(n^3 + n^2)^1/2 - (n^3 + 2n^2)^1/2}{(n^2 + 3n +2)^1/2}[/tex]
Could I say that,
[tex]\frac{(n^3 + n^2)^1/2 - (n^3 + 2n^2)^1/2}{(n^2 + 3n +2)^1/2}[/tex] < [tex]\frac{(n^3 + n^2)^1/2}{(n^2 + 3n +2)^1/2}[/tex],
then
[tex]\frac{(n^3 + n^2)^1/2}{(n^2 + 3n +2)^1/2}[/tex] < [tex]\frac{(n^3/2)}{(3n)^1/2}[/tex] = [tex]\frac{n}{3^1/2}[/tex]
But I think this won't work with the definition of a limit. Someone please help! Any hint would do, I don't want an answer. :(
lol. I don't think this converges. the numerator goes to infinity faster than the denominator. Numerator is ~n^1. Denominator is ~n^(1/2) .
If it does diverge, could I show that using the definition of a limit and reach a contradiction? I've been working on this for days, and the way the question is worded, it leads the student to think that the series converges. This is just a problem to help me prepare for the final, since it is a problem in the practice final, and it models the true quite closely. If you think my math above is correct, then it must diverge under the definition of the limit.
But then I thought about it some more, and was wondering if this was true:
[tex]\frac{(n^3 + n^2)^(1/2) - (n^3 +2n^2)^(1/2)}{(n^2 + 3n + 2)^(1/2)}[/tex] <
[tex]\frac{(n^2)^(1/2) - (2n^2)^(1/2)}{(n^2 + 3n)^(1/2)}[/tex] = [tex]\frac{n(1-\sqrt{2})}{(n^2 + 3n)^(1/2)}[/tex]
I'm really trying my best to work this out, but I can't see what I'm doing wrong here. If anyone could put me in the right direction, they would be a lifesaver. Thank you for helping me this much already pellman!
I think it is simpler than that. Let
[tex]a_n = \frac{n}{\sqrt{n+1}}-\frac{n}{\sqrt{n+2}}[/tex]
It should be straightforward to show that [tex]a_{n+1} > a_n[/tex] for all n greater than some N. I bet N is rather low, probably 1 or 2. This will require some rather tedious algebra or some clever shortcuts, if there are any.
That's what I'd try first. It might be difficult though. I don't have time to work through it myself.
You are over complicating things.
[tex]
[/tex]
[tex]
a_n = \frac{n \left( \sqrt {n+2} - \sqrt{n+1}\right)}{\sqrt{n+1} \sqrt{n+2}}
[/tex]
Rationalize to get
[tex]
a_n = \frac{n}{\sqrt{n+1} \sqrt{n+2}\left( \sqrt {n+2} + \sqrt{n+1}\right)}
[/tex]
From here it is straight forward to show that
[tex]
a_n < \frac{1}{2 \sqrt{n}}
[/tex]
So it is easy to show the limit is zero.
Sheesh. I'm getting old.
[tex]
[/tex]
[tex]
[/tex]
Rationalize to get
[tex]
[/tex]
[tex]
[/tex]
lol I actually did something like that, and worked it out last night. I ended up getting 1/E^2 :)
Combining and THEN taking the conjugate was what needed to be done. Thank you so much for your help! I feel very prepared for my final now :blushing:
PS: you're not old, you're awesome :)
Heck, I couldn't figure it out, and MANY others I went to didn't even know where to start. I'm very happy that I was able to finally get it, and I think you should be too. :)
You deserve a pat on the back!
What is the definition of a limit?
The definition of a limit is a mathematical concept that describes the behavior of a function as the input values get closer and closer to a specific value, called the limit point. It is denoted by the symbol "lim" and is used to determine the behavior of a function at a specific point.
How do you prove a limit using its definition?
To prove a limit using its definition, you must show that for any small positive number ε, you can find a corresponding value of δ such that the distance between the input values and the limit point is less than δ, the difference between the output values and the limit point is less than ε.
What is the importance of proving a limit using its definition?
Proving a limit using its definition is important because it allows us to understand the behavior of a function at a specific point and make predictions about its values. It also serves as the foundation for many other concepts in calculus, such as continuity and differentiability.
What are the steps to prove a limit using its definition?
The steps to prove a limit using its definition are as follows:1. Start with the definition of a limit: for any small positive number ε, there exists a corresponding value of δ.2. Use algebraic manipulation to rewrite the expression in terms of δ.3. Choose a value of δ that satisfies the conditions.4. Show that the distance between the input values and the limit point is less than δ.5. Show that the difference between the output values and the limit point is less than ε.6. Conclude that the limit exists and is equal to the limit point.
Can you give an example of proving a limit using its definition?
Yes, for example, let's prove that the limit of the function f(x) = x^2 as x approaches 2 is equal to 4. 1. Start with the definition of a limit: for any small positive number ε, there exists a corresponding value of δ.2. Rewrite the expression in terms of δ: |x^2 - 4| < ε.3. Choose a value of δ, say δ = 0.5.4. If |x - 2| < 0.5, then -0.5 < x - 2 < 0.5, which implies that 1.5 < x < 2.5.5. When x is between 1.5 and 2.5, x^2 will be between 2.25 and 6.25, which is within 0.5 of 4.6. Therefore, we have shown that for any ε > 0, we can find a corresponding δ = 0.5 such that |x^2 - 4| < ε. This proves that the limit of f(x) as x approaches 2 is equal to 4.
