What Is the Angle Between L and S for the Largest j and mj?
The discussion revolves around calculating the angles between angular momentum vectors in a quantum mechanics context, specifically for states with orbital angular momentum \( l=4 \) and spin \( s=1/2 \). Participants are exploring the largest possible total angular momentum \( j \) and its projection \( m_j \), as well as the relationships between the vectors \( \vec{L} \), \( \vec{S} \), and \( \vec{J} \).
  • Participants discuss geometric methods for calculating angles between angular momentum vectors, referencing the dot product and cosine law. There is inquiry into the calculation of \( \vec{L} \cdot \vec{S} \) and its implications for finding angles. Some participants suggest using the relationship between the magnitudes of the vectors and their projections on the z-axis.
The conversation is active, with various methods being proposed for calculating the angles. Some participants have provided specific calculations for \( L \cdot S \) and the magnitudes of the vectors, while others question the appropriateness of using classical vector relationships in a quantum context. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants note the importance of the quantum nature of the operators involved, which complicates the interpretation of angles between them. There is also mention of the need for clarity regarding the definitions and calculations of angular momentum in this quantum framework.
stunner5000pt
Consider the states for which l=4 and s=1/2.For the state wit hteh largest j, and the largest mj, calculate
a) the nagle between L and S
the angle between [itex]\mu_{l}[/itex] and [itex]\mu_{s}[/itex]
c) the angle between J and the +z axis
j=l+/-s
the largest possible j is 4 +1/2 which is 9/2.
the largest mj is also 9/2
since mj ranges from -j to +j.
now my prof said that this could be done gemetrically that is
since l=4, then the value of value of L is [itex]\sqrt{4(4+1)}\hbar=3\hbar[/itex]
the projection on the z axis, that is ml may be -4,-3,...,3,4
the spin s=1/2, ms=1/2
the magnitude of the spin angular momentum vector is [itex]\sqrt{3}/2 \hbar[/itex]
usig the projection of both we can draw the vectors and we can find the nagles between them
i was jjust wondering if there was a way of doing this using [itex]\vec{L} \cdot \vec{S} [/tex]<br /> <br /> [tex]L \cdot S = |L| |S| \cos \theta[/tex]<br /> <br /> the magnitude of L is calcualted above<br /> siilarly for S<br /> <br /> but how would one go about calculating L dot S?? <br /> thanks for the help![/itex]
j=l+/-s
[itex] <br /> <br /> You can always write<br /> [tex]\vec{L} \cdot \vec{S} = \frac{1}{2} \bigl( {\vec J}^2 - {\vec L^2} - {\vec S}^2 \bigr)[/tex]<br /> So this operator sandwiched between states of definite j, l and s gives [itex]\frac{\hbar^2}{2} (j(j+1) - l(l+1) -s(s+1))[/itex]. This is used in the calculation of the spin orbit interaction in hydrogen, for example.[/itex]
Someone correct me if I am wrong but:
The lengths of the vectors (L, S, J) are proportional to sqrt{l(l+1)}, sqrt{s(s+1)}, sqrt{j(j+1)}
Then maybe the angle between L and J can be had by the cosine law (which to me looks similar to what nrqed has above).
BTW check your sqrt{4(4+1)}.
here we are looking for the largest possible j so
j = 9/2
so
[tex]L \cdot S = \frac{\hbar^2}{2} (j(j+1) - l(l+1) -s(s+1)) = \frac{\hbar^2}{2} \left(\frac{9}{2}\left(\frac{9}{2} +1\right) - 4(4+1) - \frac{1}{2}\left(\frac{1}{2} +1\right) \right) = \hbar^2[/tex]
[tex]|L| = \sqrt{20} \hbar[/tex]
[tex]|S| = \sqrt{3}/2 \hbar[/tex]
are u sure it should be cosine law or dot product??
j = 9/2
so
Well, since S, L and J are really quantum operators, one cannot really see them as ordinary vectors. So it does not really make sense to talk about the angle between two operators. But people define the angle between [itex]{\vec L}[/itex] and [itex]{\vec S}[/itex] in a certain state of definite L,S and J as the ratio of the expectation values [tex]\frac{ < {\vec L } \cdot {\vec S} >} { \sqrt{ < {\vec L}^2 >} \sqrt{ < {\vec S}^2>}}[/tex]
