Thread Closed
Work done on the block by force
Share Thread Thread Tools
Jul23-09, 06:17 AM   #1
A block is pushed across a rough horizontal surface from point A to point B by a force (magnitude P = 5.4 N) as shown in the figure. The magnitude of the force of friction acting on the block between A and B is 1.2 N and points A and B are 0.5 m apart. If the kinetic energies of the block at A and B are 4.0 J and 5.6 J, respectively, how much work is done on the block by the force P
between A and B?
2. Relevant equations
W= PCos (theta)D
3. The attempt at a solution
I have no idea what to do for this!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jul23-09, 06:33 AM   #2
I suppose Work done on the block = change in kinetic energy + work against friction
Jul23-09, 07:00 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Zmuffinz! Welcome to PF!
(have a theta: θ )
Quote by Zmuffinz View Post
W= PCos (theta)D
Well, what is θ in this case?
Jul25-09, 06:19 AM   #4
well you see thats why im stuck, i wasnt given an angle, or mass of the block or anything so ive got no clue as to what to do:(
Jul25-09, 06:20 AM   #5
Quote by songoku View Post
and how do i calculate work against friction?
Jul25-09, 07:15 AM   #6
Mentor
You didn't post the diagram, but I presume that the force was applied horizontally. That will tell you all you need about angles.
Thread Closed
Thread Tools
Similar Threads for: Work done on the block by force
Thread Forum Replies
Work on Block with an opposing force Introductory Physics Homework 3
Force needed to keep block from moving on frictionless triangular block Introductory Physics Homework 1
Work on a sliding Block Introductory Physics Homework 9
Work done by a friction force, block moving up a ramp--question Introductory Physics Homework 12
