Yield stress from tensile test and yield stress from hardness tests
The discussion highlights the discrepancies between yield stress obtained from tensile tests and that derived from hardness tests. It establishes that hardness tests are nonlinear and provide only approximate values for yield strength, relying on generalized relationships. This distinction is crucial for material scientists and engineers when selecting appropriate testing methods for accurate yield stress determination.
  • Understanding of tensile testing methodologies
  • Familiarity with hardness testing techniques
  • Knowledge of material properties and stress-strain relationships
  • Basic principles of nonlinear testing analysis
  • Research the correlation between hardness and yield strength in various materials
  • Explore advanced tensile testing methods and their applications
  • Learn about the limitations of hardness tests in material characterization
  • Investigate the use of finite element analysis (FEA) in predicting yield stress
Material scientists, mechanical engineers, and quality control professionals involved in material testing and evaluation will benefit from this discussion.
mh1985
Why can there sometimes be a difference observed between them?
Because a hardness test is a highly nonlinear test which is only able to approximate yield strength of the material using some loose relationships.
  • · Replies 20 ·
