How Do You Calculate the Center of Mass of a Nonuniform Bar Suspended by Wires?
  • Thread starter PSEYE
  • Tags
    Wires
In summary: Check your equations again!In summary, the problem involves a nonuniform horizontal bar of mass m supported by two massless wires against gravity. The position of the center of mass of the bar, measured as distance x from the bar's left end, is calculated using the equations -F₁ · sin(φ₁) + F₂ · sin(φ₂) = 0 and x = L / ( (F₁/F₂)·(cos(φ₁)/cos(φ₂)) + 1). However, the attempt at a solution using x = L / ( (tan(φ₂)/tan(φ₁) + 1) is incorrect and the correct method involves eliminating unknown forces using moments about a point through their
PSEYE
A nonuniform horizontal bar of mass m is supported by two massless wires against gravity. The left wire makes an angle (phi) with the horizontal, and the right wire makes an angle . The bar has length L.
What is the position of the center of mass of the bar, measured as distance from the bar's left end?
x=?
___________________________________
F₁x = -F₁ · sin(φ₁)
F₁y = F₁ · cos(φ₁)
F₂x = F₂ · sin(φ₂)
F₂y = F₂ · cos(φ₂)
forces in terms of magnitude and angle
this seems right, but I'm repeatedly getting it wrong no matter how I input the answer.
take moments …
Hi PSEYE! :smile:
Sorry, but I've no idea how you got that result. :confused:
You have three unknown forces, F1 F2 and W, which you don't want in the final equation.
The only ways I know to eliminate unknown forces are:
i] take components perpendicular to them … which isn't going to work in this case … or
ii] take moments about a point through their line of action.
Try ii]! :smile:
F₁x = -F₁ · sin(φ₁)
F₁y = F₁ · cos(φ₁)
F₂x = F₂ · sin(φ₂)
F₂y = F₂ · cos(φ₂)
If phi_1 and phi_2 are the angles with the horizontal, you've got your sines and cosines mixed up.
Related to How Do You Calculate the Center of Mass of a Nonuniform Bar Suspended by Wires?
What is a bar suspended by two wires?
A bar suspended by two wires is a physical system where a straight rigid bar is attached to two points by wires, creating a triangular structure. This type of system is commonly used in construction and engineering to distribute weight and provide stability.
How does a bar suspended by two wires work?
The bar suspended by two wires works by distributing the weight of the bar evenly between the two wires. The tension in each wire helps to keep the bar stable and prevents it from rotating or moving out of position. This system is based on the principles of equilibrium and Newton's laws of motion.
What factors affect the stability of a bar suspended by two wires?
The stability of a bar suspended by two wires is affected by several factors, including the length and weight of the bar, the tension in the wires, and the angle at which the wires are attached to the bar. Additionally, external forces such as wind or vibrations can also affect the stability of the system.
How is the tension in the wires calculated?
The tension in the wires of a bar suspended by two wires can be calculated using the principles of equilibrium and the geometry of the system. The sum of the forces acting on the bar must be equal to zero, and the angles and lengths of the wires can be used to determine the tension in each wire.
What are some real-world applications of a bar suspended by two wires?
A bar suspended by two wires has many real-world applications, including in bridges, cranes, and other large structures where weight distribution and stability are crucial. It is also used in smaller scale systems, such as in hanging shelves or clotheslines. Additionally, this system is used in physics demonstrations to illustrate principles of equilibrium and tension.
9K
