Circular orbit + small radial oscillation about circular orbit
In summary: Omega \Delta t$. Since we know that the orbit precesses at an angular velocity of $\Omega$, we can see that the change in the angular frequency of small oscillations is directly related to the angular velocity of precession. This means that as the orbit precesses, the angular frequency of small oscillations changes, which shows that the orbit is approximately an ellipse with precession. In summary, we have shown that a nearly circular orbit is approximately an ellipse with precession, where the axes of the ellipse precess at an angular velocity given by $\Omega \simeq \frac{c}{\vert k \vert a
unitdisk
The potential energy of a particle of mass $m$ is $U(r)= k/r + c/3r^3$ where $k<0$ and $c$ is very small. Find the angular velocity $\omega$ in a circular orbit about this orbit and the angular frequency $\omega'$ of small radial oscillation about this circular orbit. Hence show that a nearly circular orbit is approximately an ellipse whose axes precess at an angular velocity $\Omega \simeq (c/\vert k \vert a^2) \omega$
\begin{equation}L= \frac{m}{2}(\dot{r}^2 + r^2 \dot{\theta}^2) - U
\end{equation}
\begin{equation}\frac{\partial L }{\partial r} = mr\theta^2 - \frac{\partial U}{\partial r}
\end{equation}
\begin{equation}\frac{d}{dt} \frac{\partial L }{\partial \dot{r}} = m\ddot{r}
\end{equation}
\begin{equation} m\ddot{r} - mr \dot{\theta} ^2 = - \frac{\partial U}{\partial r} \tag{1} \end{equation}
$\ddot{r} = 0$ at $r=a$.
Thus \begin{equation}-ma \omega ^2 = -\frac{\partial U}{\partial r}\big\vert_a = \frac{k}{a^2}+\frac{c}{a^4}\end{equation}
\begin{equation} \omega^2 = \frac{(ka^2+c)}{m a^5}\end{equation}
\begin{equation}\omega = \sqrt{\frac{(ka^2+c)}{m a^5}} \end{equation}
$l= mr^2 \dot{\theta}$ is constant.\begin{equation}V(r) = U(r) + \frac{l^2}{2m r^2}
\end{equation}
\begin{equation} \ddot{r} - r \dot{\theta}^2 = -\frac{1}{m} \frac{\partial U}{\partial r}= \ddot{r} - \frac{l^2}{m^2 r^3} \tag{2}
\end{equation}
Consider small oscillation where $r=a$ changes to $r=a+x$.
Then $\ddot{r}=\ddot{x}$.
Thus (2) becomes \begin{equation}\ddot{x} - \frac{l^2}{m^2 (a+x)^3} = -\frac{1}{m}\frac{\partial U}{\partial r}\bigg\vert_{a+x} \end{equation}
\begin{equation} \ddot{x} - \frac{l^2}{m^2 a^3} (1+ \frac{x}{a})^{-3} \simeq \ddot{x} - \frac{l^2}{m^2 a^3} (1- \frac{3x}{a}) \tag{3}\end{equation}
\begin{equation}-\frac{1}{m}\frac{\partial U}{\partial r}\bigg\vert_{a+x} \simeq -\frac{1}{m}[\frac{\partial U}{\partial r}\bigg\vert_{a} + \frac{\partial ^2 U}{\partial r ^2}\bigg\vert_a x ]
\tag{4}\end{equation}
(2) at $r=a$ is
\begin{equation}-\frac{1}{m}\frac{\partial U}{\partial r}\big\vert_{a}= -\frac{l^2}{m^2 a^3}
\end{equation}
Thus (3)=(4) yields
\begin{equation} \ddot{x} + \frac{1}{m}(\frac{a}{3}\frac{\partial U}{\partial r}\big\vert_{a} +\frac{\partial ^2 U}{\partial r ^2}\big\vert_a )x = 0\end{equation}
Thus \begin{equation} \omega'^2 = \frac{1}{m}(\frac{a}{3}\frac{\partial U}{\partial r}\big\vert_{a} +\frac{\partial ^2 U}{\partial r ^2}\big\vert_a ) =- \frac{k}{ma^3}+\frac{c}{ma^5} \end{equation}
\begin{equation}
\omega^2= - \frac{k}{ma^3}-\frac{c}{ma^5}
\end{equation}
\begin{equation}
\omega'^2 = - \frac{k}{ma^3}+\frac{c}{ma^5}
\end{equation}
\begin{equation}\frac{\omega'^2}{\omega^2} = \frac{-k a^2 + c}{k a^2 + c}
= 1 + \frac{2c}{\vert k \vert a^2 -c} \simeq 1 + \frac{2c}{\vert k \vert a^2} \end{equation}
\begin{equation} \omega^2 - \omega'^2 \simeq \frac{2c \omega^2}{\vert k \vert a^2}
\end{equation}
\begin{equation}
\omega - \omega' \simeq \frac{2c \omega^2}{\vert k \vert a^2 (\omega+ \omega ')} \simeq \frac{2c \omega^2}{\vert k \vert a^2 (2\omega)}=\frac{c \omega^2}{\vert k \vert a^2 \omega}\end{equation}
How should I show that circular orbit with small oscillation is approximately an ellipse with precession? Also why is angular velocity of prececssion $\Omega = \omega - \omega'$?
To show that a nearly circular orbit is approximately an ellipse with precession, we can use the fact that the angular frequency of small radial oscillations $\omega'$ is related to the angular velocity of precession $\Omega$ by $\Omega = \omega - \omega'$. This means that the difference between the angular frequencies of the circular orbit and small oscillations is equal to the angular velocity of precession.
We can then use this relation to show that the orbit is approximately an ellipse by considering the change in the angular frequency of small oscillations as the orbit precesses. As the orbit precesses, the angular frequency of small oscillations changes by a small amount, which can be approximated by $\Delta \omega' = \Omega \Delta t$, where $\Delta t$ is the time it takes for the orbit to precess by a small angle.
Using the relation between $\omega'$ and $\omega$, we can rewrite this as $\Delta \omega' = (\omega - \omega') \Delta t$. We can then substitute in the expression for $\Delta \omega'$ from equation (14) to get $\Delta \omega' = \frac{c \omega^2}{\vert k \vert a^2 \omega} \Delta t$.
Next, we can use the fact that the angular frequency of small oscillations is related to the potential energy by $\omega'^2 = - \frac{1}{m} \frac{\partial U}{\partial r} \big\vert_{a}$, which we can rewrite as $\omega'^2 = \frac{k}{ma^3} + \frac{c}{ma^5}$. Substituting this into our equation for $\Delta \omega'$, we get $\Delta \omega' = \frac{c}{\vert k \vert a^2 \omega} (\frac{k}{ma^3} + \frac{c}{ma^5}) \Delta t$.
Finally, we can use the fact that the angular velocity of precession is related to the potential energy by $\Omega = \frac{1}{m} \frac{\partial U}{\partial r} \big\vert_{a}$, which we can rewrite as $\Omega = \frac{k}{ma^3} + \frac{c}{ma^5}$. Substituting this into our equation for $\Delta \omega'$, we get $\Delta \omega
1. What is a circular orbit?
A circular orbit is a type of orbit in which an object moves around another object in a perfect circle. The object being orbited is located at the center of the circle.
2. How is circular orbit different from other types of orbits?
Circular orbit differs from other types of orbits, such as elliptical or parabolic orbits, in that it has a constant distance from the center of the orbiting object. This means that the speed and direction of the orbiting object remains constant throughout the orbit.
3. What is small radial oscillation in relation to circular orbit?
Small radial oscillation refers to the slight deviation from a perfect circular orbit. This can be caused by gravitational pull from other objects or changes in the speed of the orbiting object.
4. Why is small radial oscillation important in circular orbit?
Small radial oscillation can affect the stability and predictability of a circular orbit. It can also impact the energy and trajectory of the orbiting object.
5. Can circular orbit with small radial oscillation occur in nature?
Yes, circular orbit with small radial oscillation can occur in nature. For example, the orbits of planets in our solar system have small radial oscillations due to gravitational pull from other planets and the Sun. Additionally, artificial satellites in Earth's orbit also experience small radial oscillations.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
