Combined lens & mirror system
In summary: So you could then have calculated the image due to the lens.But in this case, the mirror and lens are not close enough together for that to be possible.
horsedeg
39
The object in the figure below is midway between the lens and the mirror, which are separated by a distance d = 24.9 cm. The magnitude of the mirror's radius of curvature is 20.4 cm, and the lens has a focal length of -16.5 cm.
(a) Considering only the light that leaves the object and travels first toward the mirror, locate the final image formed by this system.
(b) Is this image real or virtual?
(c) Is it upright or inverted?
1/p + 1/q = 1/f
Considering only the light that goes to the mirror, I plugged in the focal point of the mirror (using the radius) as well as the object distance (p) to the formula above and this would give me the virtual image (q) created by the light going into the mirror. This gives me a distance of 56.44 to the left of the mirror. Ideally this would become the real object for the lens, but I don't see how it makes sense in this case. Wouldn't the light be going through the lens on the way from the mirror to the location of the virtual image? Is there something I'm misunderstanding? In addition, as a result the object location that would be used for the lens in the equation would supposedly be negative as well and I'm not sure why. I guess it makes sense because if someone was looking at the system from the left through the lens to look at the object, the projected object would be behind the lens which would mean it is negative for a real object. Just doesn't make sense to me when considering the previous issue though.
Even though both lenses and mirrors use the equation [itex]\frac{1}{p} + \frac{1}{q} = \frac{1}{f}[/itex], the quantity [itex]q[/itex] is measured differently in the two cases. For a lens, positive [itex]q[/itex] means on the opposite side of the object, while negative [itex]q[/itex] means on the same side. For a mirror, positive [itex]q[/itex] means on the same side as the object, while negative [itex]q[/itex] means on the opposite side.
So in your case, for the mirror, you get [itex]-56.44[/itex]. Since that's negative, it's on the opposite side of the mirror from the object. So this image is to the right of the mirror, not the left.
But your post has another error: you say "Wouldn't the light be going through the lens on the way from the mirror to the location of the virtual image?".
If your calculation had been correct, and the image due to the mirror had been to the left of the lens, then that would have been a case of a "virtual object", one with a negative value of [itex]p[/itex]. The formula relating p, q and f still works in that case.
1. What is a combined lens and mirror system?
A combined lens and mirror system is a type of optical system that uses both lenses and mirrors to manipulate and focus light. This system is commonly used in telescopes, microscopes, and other optical devices.
2. How does a combined lens and mirror system work?
The lens in the system bends and refracts light, while the mirror reflects and directs the light. Together, these components work to focus the light onto a specific point or image.
3. What are the advantages of using a combined lens and mirror system?
One advantage is that it allows for a larger field of view compared to using just one component. Additionally, it can correct for certain aberrations that may occur with just a lens or mirror alone.
4. What are some common applications of a combined lens and mirror system?
Combined lens and mirror systems are commonly used in telescopes, microscopes, projectors, and cameras. They are also used in laser systems and in some medical and scientific instruments.
5. Are there any disadvantages to using a combined lens and mirror system?
One potential disadvantage is that the system can be more complex and expensive compared to using just one component. Additionally, the alignment of the lenses and mirrors must be precise in order for the system to function properly.
