How Can I Derive the Kepler Equation?
In summary, the Kepler equation relates mean anomaly and eccentric anomaly, which are both measured on the orbital plane. Mean anomaly is not an angle, but rather a time domain measurement, while eccentric anomaly is a physical angle. The confusion may arise due to the use of "ecliptic plane," which can refer to either the Earth's ecliptic plane or the orbit plane of a planet, moon, or satellite. However, these are not necessarily the same.
Philosophaie
462
I am trying to derive the Kepler equation:
M = E - e * sin(E)
where M=Mean Anomaly, e=Eccentricity and E=Eccentric Anomaly.
If you drop a perpendicular down from the object to the Perihelion-axis you can take:
a * cos(E) = a * e + Recl * cos (TA)
where Recl is the Ecliptic radius to the object from the Sun and TA=True Anomaly.
I am having a hard time equating M and TA because one is on the Ecliptic Plane and the other is on the Orbiting Plane.
Any hints are appreciated.
Astronomy news on Phys.org
Mean anomaly and true anomaly are usually both measured in the plane of the orbit, so I guess I don't understand the question.
Try going at it using the conservation of momentum/inertia..
This is not the case, which is probably why you are confused. Mean anomaly is not an angle. It is merely the mean anomaly at some epoch time plus the product of time since that epoch and mean motion. There is no meaningful angle you can draw that represents mean anomaly. Kepler's equation relates mean anomaly to eccentric anomaly (which is an angle). Both eccentric anomaly and true anomaly are measured on the orbital plane rather than on the ecliptic.
Orbit of a planet or the orbit of a moon orbiting a planet or the orbit of a satellite orbiting the Earth?
If you're talking about a planet's orbit, the ecliptic plane of that planet (not the ecliptic plane, which normally refers to the Earth's ecliptic plane), then the ecliptic plane is the orbit plane of that planet. Using ecliptic plane in a generic question about orbits really creates a lot of confusion, probably for yourself, as well, since you seemed to believe they were referring to two separate planes. If you're talking about the Moon's orbit, then the Moon's orbital plane definitely is not the same as the ecliptic plane (and the orbital plane of a satellite will not be the ecliptic plane).
But, as DH said, it's going to be hard to find a geometric comparison between Mean Anomaly and Eccentric Anomaly. Mean Anomaly refers to the time domain. It's your location in time relative to perigee (the time you were at perigee). Eccentric Anomaly refers to the physical domain and represents an actual physical angle relative to perigee.
What is the Kepler equation?
The Kepler equation is a mathematical formula that describes the relationship between the orbit of a planet and its position at a specific time. It was developed by Johannes Kepler in the 17th century and is used to calculate the position of planets in their orbits.
How is the Kepler equation derived?
The Kepler equation is derived from Kepler's three laws of planetary motion, which state that planets move in elliptical orbits around the sun, sweep out equal areas in equal times, and have a relationship between their orbital periods and distances from the sun. Using these laws, Kepler was able to develop the equation that describes the position of a planet in its orbit at a given time.
What are the variables in the Kepler equation?
The variables in the Kepler equation include the eccentricity of the orbit (e), the mean anomaly (M), the eccentric anomaly (E), and the true anomaly (ν). These variables represent different aspects of a planet's orbit and its position at a specific time.
How accurate is the Kepler equation?
The Kepler equation is considered to be highly accurate in predicting the position of planets in their orbits. However, it does not take into account the gravitational influence of other planets or objects, which can affect the precise position of a planet in its orbit.
What is the significance of the Kepler equation?
The Kepler equation is significant because it provided a mathematical framework for understanding the motion of planets in our solar system. It also paved the way for future advancements in astronomy and space exploration.
  • Astronomy and Astrophysics
  • Classical Physics
  • Classical Physics
  • STEM Educators and Teaching
