How Do Sign Conventions Affect Focal Length Calculations?
In summary: The sign convention will tell you the correct answer. In summary, you need to be familiar with the sign conventions for R and f in order to correctly use the formulas in your calculations.
Noreturn
49
1) A double convex thin lens has a radius of 25 cm for the first surface and a radius of 40 cm for the second surface. If the glass has a refractive index of 1.55 the focal length is a) 28 cm, b) 9.93 cm, c) 121 cm, or d) 63 cm.
2) An object is placed 16 cm in front of a thin concave lens of 10 cm focal length, therefore the image distance
1/f=(n-1)((1/R1)-(1/R2))
1/f=(1/s)+(1/s^1)
f=((1.55-1)((1/25)-(1/40)))^-1121cm
s^1=((1/10)-(1/16))^-1
26.67
However, they have the answer as A) 28cm and -6.15
Review the various sign conventions. You have one sign error in your calculation of f and one sign error in your calculation of s.
In optics, you have to be especially cautious of your signs.
1) Check your signs for R1 and R2 for a double convex lens.
2) Check your focal length for a diverging lens.
Where did I mess up, It looks like I followed the equation that was given to us. I tried adding instead of subtracting and still got the wrong answer.
When is R negative?
When is f negative?
I still was not able to get this answer correctly, or answer when it's negative :(
Usually it's negative for diverging lens correct?
Please show your calculation with all of the individual steps and numbers that you used. Otherwise, we can't identify where you are making an error.
f=((1.55-1)((1/25)+(1/40)))^-1
f= ( (.55) (.065) )^-1
f= 28cm
So I did figure out 2:
s= ((1/10)+(1/16))^-1
Then the answer is negative on part 2 why? Then on both of them we have to end up adding instead of subtracting why is that?
As mentioned earlier, the reason has to do with sign conventions for R and f. These sign conventions should have been stated in your textbook or in your lectures.
In part (a) you are given that the radius of curvatures of the first and second surfaces are 25 cm and 40 cm, respectively. When using the formula that contains R1 and R2, you need to use the sign conventions in order to decide if R1 = +25 cm or R1 = -25 cm. Likewise, the sign conventions will tell you whether to use R2 = +40 cm or R2 = -40 cm.
Similarly, for part (b), you need to know the sign convention for when f is positive and when f is negative. When the problem states that the focal length is 10 cm, they are just giving you the magnitude (absolute value) of the focal length. They are leaving it to you to decide if f = + 10 cm or f = -10 cm when using the formula.
What is focal length?
Focal length is the distance between the center of a lens or curved mirror and its focus. It is typically measured in millimeters (mm).
How does focal length affect the appearance of an image?
The focal length determines the magnification and angle of view of an image. A shorter focal length will result in a wider angle of view and a smaller magnification, while a longer focal length will result in a narrower angle of view and a larger magnification.
What is the difference between a short and long focal length?
A short focal length (wide-angle lens) will capture a wider angle of view, making objects appear smaller and farther away. A long focal length (telephoto lens) will capture a narrower angle of view, making objects appear larger and closer.
Can I change the focal length of a lens?
Yes, some lenses have a variable focal length, allowing you to adjust the magnification and angle of view. These are known as zoom lenses. Other lenses have a fixed focal length, also known as prime lenses.
How does the sensor size of a camera affect the focal length?
The sensor size of a camera can affect the effective focal length. For example, a camera with a smaller sensor will have a crop factor, meaning the focal length will appear longer than it actually is. This is important to consider when choosing lenses for different types of cameras.
