ghostops
- 14
After a laser beam passes through two thin parallel slits, the first completely dark fringes occur at ±14.0∘ with the original direction of the beam, as viewed on a screen far from the slits.
A)What is the ratio of the distance between the slits to the wavelength of the light illuminating the slits?
d/lambda = 2.07
B)What is the smallest positive angle, relative to the original direction of the laser beam, at which the intensity of the light is 110 the maximum intensity on the screen?
Θ=
I = Iocos2(ø/2)
ø = 2∏dsinθ/λ
so for this I solved for phi and then substituted that into the second equation and for this sinθ is ≈θ I just solved for theta in the 2nd equation
for ø= 2cos-1(√(1/10))
ø=2.498
then ø/(2∏(d/λ)) = Θ
for Θ I got .192 but I can't figure out what I did wrong
thank you in advance
