How can I achieve homogeneous in-line mixing of a Coolant with water?
This discussion focuses on achieving homogeneous in-line mixing of an alkaline chemical with water for a CNC machine or part washer application. The user, KV, plans to mix 1 liter of alkaline chemical (pH 8-12) with 50 liters of water using a gravity-fed system and a metering or gear pump. The proposed solutions include using a static mixer or an injection quill, although KV expresses concerns about their effectiveness. Tom provides links to disposable mixers and suggests researching 2-part mixing dispensers and inline mixing nozzles.
  • Understanding of fluid dynamics and mixing principles
  • Familiarity with metering and gear pumps
  • Knowledge of flow sensors and control valves
  • Experience with static mixers and injection quills
  • Research static mixer designs and their effectiveness for chemical mixing
  • Explore inline mixing nozzle options and specifications
  • Investigate the use of flow sensors for precise chemical dosing
  • Examine case studies on in-line mixing systems in industrial applications
Engineers, product designers, and technicians involved in fluid mixing applications, particularly in CNC machining and part washing processes.
kunalvanjare
Hello guys,
This is for a new product I am designing, which involves topping-up or refilling the liquid into a CNC Machine or Part Washer.
I have to mix about a Litre of the chemical (alkaline.. pH in the range of 8-12) with about 50 Litres of water. The water will be fed under gravity through a 1" pipe, while the chemical will be pumped using a Metering or Gear pump either from a Chemical Barrel or a Tank.
Flow-rate of both the chemicals will be controlled with the help of flow sensors & valves because the system has to automatically calculate the quantity of each liquid as per inputs from the user.
Now, my question is how do I achieve mixing of both the chemicals to produce a homogeneous mixture? The objective is to do this in-line without use of an additional Tank & Agitator. I have pondered about using a Static Mixer or an Injection Quill, but I am not convinced I'll get a homogeneous mixture from these.
I simply cannot afford space for an external mixing tank as the output of my 'Dispenser' will be connected straight to the machine.
Request somebody with prior experience on similar fields to suggest or guide me towards a solution.
Thanks,
KV
12K
  • · Replies 19 ·
