Our Beautiful Universe - Photos and Videos
2,446 replies · 316K views
Monkey head nebula. Total integration time 30 minutes, via Tecnosky 70/420 Apo, with ASI 533 color camera, on iOptron SkyHunter mount, guided.
Processed with Pixinsight and SetiAstroSuite.
Bortle 7, Ploiești, Romania.
Reply
  • Love
Astronomy news on Phys.org
Rosette nebula. Total integration time 60 minutes.
With Canon 600 D, on iOptron SkyGuiderPro mount, through APO Tecnosky 70/420, Ploiești, bortle 7, Romania.
Initial processing with Pixinsight and later reprocessed with SetiAstroSuite.
Reply
  • Love
Planet Jupiter, through mak 127/1500, 2x barlow, 3 minutes integration.
Processing with PIPP, AS3 and Registax. Denoising with PS.
Reply
  • Love
M 51. 4 hours total integration (2 nights), with Seestar S50.
Processing and editing with Pixinsight and SetiAstroSuite.
Ploiești, Romania, bortle 7
Reply
  • Love
Andy Resnick said:
Since I'm not willing to chop down trees to increase my field of view, the only thing I could image for the past month has been M27 (Dumbbell nebula):
1:1 crop
Nikon D810 + Nikkor 800/5.6 @ f/8, 6s subs, 14.5 hours viewing time on Losmandy GM-8, stacking and post-processing using Astro Pixel Processor.
Not only is the nebula and neighborhood rather boring (all things considered), it's also hard for me to image well because of the low elevation (poor seeing) and nearness to celestial equator (which is why the subframe time is so short). At least the final result looks good.... sigh.
Wow, this is high quality. Professional observatories from a hundred years ago and much bigger telescopes could not compete with your work, probably cos CMOS tech can show more contrast compared to film. Goes to show how much telescope tech evolved. And hey, sacrificing one or two trees for great pictures may be alright. Potentially plant two or three trees in an area you will not be using your telescope.
Helix nebula. Is a planetary nebula, lies about 650 light-years, in the constellation Aquarius.
Image taken with Seestar S50, from Şirnea, BV, Romania.
The target was at low altitude and atmospheric turbulence made its presence felt. Only 40 minutes total integration time. Out of 2 hours of total exposure of 10 seconds each, many were rejected for stacking.
Processing and editing with Pixinsight and Seti Astro Suite.
Reply
  • Love
Thanks for the compliments!
Reply
You're welcome, man.
The moon and jupiter are close enough to capture @ 400mm (about 7 degrees separation), I "helpfully" magnified jupiter pasted it on to better see the detail, one exposed to see the lunar and planetary details, and another exposed to show the 4 galilean moons:
Reply
Not many clear nights lately, but I managed to get a reasonable image in the region of IC 434 (Horsehead Nebula in Orion):
Nikon D810 + Nikkor 400/2.8, shot @ f/4 on Losmandy GM-8, 10s subs 25h total integration time, stacking and post processing with AstroPixelProcessor.
This region of the sky has remained very challenging for me to image, so I'm pretty happy how this has been evolving.
There's TONS of deep sky objects in this field of view, including M78 in the top left corner (with all the stacking artifacts). I'll show a 200% crop of IC 426, a molecular cloud:
I'm pleasantly surprised that my equipment is able to scavenge enough photons to reconstruct a molecular cloud, for sure- it's barely above the noise floor. Plus, the shape resembles a dancing mushroom from the film "Fantasia" :)
Reply
  • Agree
  • Love
Jupiter 2026-02-14 06:41.4 UT.
After several weeks and many nights of bad seeing, clouds, terabytes of wasted data, and whatnot, I finally was able to acquire this image. The seeing wasn't great, but it was the best I've had in all my recent attempts (which isn't saying much). This is likely my last attempt at Jupiter for this apparition.
Equipment:
Celestron C14 EdgeHD telescope.
SkyWatcher EQ8-R Pro mount.
TeleVue 2X Powermate.
Astronomik RGB filters with ZWO filter wheel.
ZWO ASI290MM monochrome camera.
Acquisition:
Atmospheric seeing was only mildly weird and pissed-off.
10 ms subframe exposure time (all colors).
Three separate 1-minute videos taken for each color, alternating RGBRGBRGB (9 minutes total).
Dark frames also acquired.
Processing:
Each video processed with Autostakkert! to create unsharpened image (9 images total)
o Best 70% of frames kept.
o No normalization.
o 3x Drizzle.
o No sharpening.
o Dark, calibration frames used.
Initial sharpening in PixInsight.
o "Convolution" processes to mitigate drizzle artifacts.
o "MultiscaleLinearTransform" for the heavy lifting of sharpening.
o "Pixelmath" to multiply by a circular mask to eliminate stacking artifacts at frame edges.
Derotation of frames using WinJUPOS (takes 9 sharpened frames and produces, 3 sharpened, derotated frames; one frame for each color).
Channel combination also done using WinJUPOS to create a single, sharpened, derotated, RGB color image.
Second round of sharpening/editing using PixInsight.
o "CurvesTransformation" for relative color corrections/adjustments.
o "UnsharpMask" for a bit more sharpening.
o RC Astro NoiseXTerminator plugin for noise reduction.
o DynamicCrop process for cropping.
Final, minor adjustments; resizing; and JPEG conversion performed in Adobe Lightroom.
Learned readers are correct to question my aggressive drizzle strategy (3x). After all, the data is already oversampled and the drizzle algorithm produces diminishing returns for oversampled data. It was more about producing a larger image than it was about eking out any extra detail. I've had luck in past years using this method compared to simple upsampling. But I concede the difference might be negligible.
Reply
  • Love
  • Agree
Hello, this Saturday was clear sky although before full moon.. I attach some images from Bohmerwald
-Jupiter, Orion neb. center, Moon and sunspots..
Lot of succes 👍 :nb)
Reply
Anyone get the Blood moon?
Reply
Hi, here is my best Jupiter up to now+orion trapezium from Bohmerwald this Saturday (eyepiece camera Bresser +Newton 1000/200 mm)
:wideeyed::smile:
Reply
Had a few clear nights during the past week, here's M44 (Beehive cluster/Praesepe):
Definitely happy with the outcome, especially the jewel-toned stars. Astrometry.net picked up 6 galaxies, but there are another half-dozen that it missed (for example, the imaginatively named Z 89-66, 2MFGC 6800 and Z 89-56)
Nikon D810 + Nikkor 800/5.6 (shot @ f/8) on Losmandy GM-8, 9h total integration time (10s subs). Stacking etc. in AstroPixel Processor.
Reply
Took this a few weeks ago, forgot to share. I've forgotten the camera settings (400mm @f/4 lens, tho...):
Jupiter (visible as a tiny dot in the lower right) was at closest approach to the moon; this is a single shot @ 400mm. The surprising thing (to me) is that both the moon and jupiter are properly exposed, indicating they have the same brightness (not to be confused with irradiance). I (digitally) magnified the tiny dot and pasted it to show that even at this comparatively low magnification, surface features are still visible (and aberrated.... thanks, sky!).
Reply
THis thursday was again clear without moon- I took again Orion Trapeizum and Jupiter.. (unfortunately Andromeda get to low quite soon evening).
lot of succes 👍 :smile:
Reply
Artemis II has now launched and is on the way to the Moon:
NASA's Artemis II Moon Mission Lifts Off
NASA said:
At 6:35 p.m. EDT (2235 UTC) on April 1, 2026, four astronauts lifted off on Artemis II for an approximately 10-day mission around the Moon.
NASA astronauts Reid Wiseman, Victor Glover, Christina Koch, and CSA (Canadian Space Agency) astronaut Jeremy Hansen launched on a test flight to bring humans closer to living on the Moon and Mars.
Credit: NASA
By pure coincidence I shot the Moon on April 1:
Gear: Sony A6500 + Tokina 400mm f/5.6 + 2x teleconverter.
The quality would have been better if I used my telescope, but I wanted to try this setup using a 2x teleconverter, yielding a focal length of 800mm.
Reply
An older image of the Jellyfish Nebula (07.02.2024), taken with Asi 533 Mc pro, on Apo TecnoSky 70/420 and iOptron SkyHunter mount (guided); NINA for everything.
120 seconds exposure each frame, total integration time one hour.
Initial processing with PixInsight, trial version and then recently re-edited with SetiAstroSuite.
Ploiești, Romania, bortle 7.
Reply
  • Love
Clear nights have been scarce lately, but tonight I was able to image Jupiter and the Galilean moons:
This is a 200% crop from a single shot (14-bit RAW) that I saved as 2 jpgs, one tone-mapped to make the moons visible (so the planet was overexposed) and the other tone-mapped to reveal the planet (and the moons were lost in the dark background). Then I just cut-n-pasted one onto the other. I was surprised that 14 bits is sufficient to encode for the disparity in magnitude (about 7, spanning -2 to 5)... that works out to a brightness ratio of 1:600, so 14 bits can easily resolve that. Cool!
Image taken with Nikon D810 + Nikkor 800/5.6 (shot @ f/8), 1/100 s ISO 200.
Reply
Great pic - just so as we have an idea of distances (and earth comparision) , can you perhaps add a rough scale to your pic ?
Astronomy gear for those who are very, very dedicated... :biggrin:
AstroHaven Trailer
Page said:
Astro Haven Enterprises (AHE) introduces a mobile platform for telescopes and optical instruments that includes an AHE composite clam shell dome. The AHE Optics Trailer lowers the telescope or optical instrument to the ground isolating it from the trailer and dome. The trailer features air suspension for off-road and with an AHE "X" dome can collapse to 8 feet wide for travel on public roads.
Reply
Thanks, but I don't understand...? Jupiter's diameter is 143000 km, if that's what you mean.
Not quite done, but good enough for now:
This panorama of the Virgo cluster is (approximately) 3 x 4 fields using my 400mm lens covering (about) 15 x 10 degrees of sky. Markarian's chain and associated 'loop' of Messier objects fit nicely in a single field of view:
It's taken a while but noise levels are finally becoming tolerable, even at 1:1 (Pinwheel galaxy):
Deets: Nikon D810 + Nikkor 400/2.8 shot @ f/4 on Losmandy GM-8, 15s subs. All image processing (stacking and stitching) done with Astro Pixel Processor. Each stack has about 4000s integration time, and 40 (!!!) stacks were required to really smooth out the background.
Reply
No sooner did I share the Virgo panorama than we just had 10 consecutive nights of clear skies. I used most of those to complete the panorama (post-processing is ongoing). I had 2 days to spare, which I used to try imaging NGC 4565- this is a 1:1 crop at 800mm focal length:
(Nikkon D810 + 800/5.6 Nikkor @ f/8, etc. etc.) There's only 4688s total integration time, so it's still quite noisy. But the object is quite large (in subtended angle)- much larger than I expected. It's also in a relatively star-free location of the sky- in the full frame, the two brightest stars only have magnitude 8.7 (the two bright stars above are magnitude 14!). There are numerous galaxies in the field of view, but I haven't yet accumulated enough observation time to pull them out of the background.
Reply
Ok thanks - that gives an idea of its relative size. About 11 times Earth diameter. And Earth's diameter (12742km) in turn is a bit more than twice that of Jupiter's largest moon Ganymede (5268km).
Final image, ready for printing, of the Virgo Cluster. The image area is approximately 14 degrees on a side:
At 1:1, it looks like this-
The image, if square format, is 16,900 pixels on a side. Assuming your display is about 300 pixels per inch, the full image at this display format would be 4.5 feet (0.3 m) across. If printed more like a poster (80 dpi), the image would be nearly 18 feet on a side.
Reply
  • Love
So many galaxies! Hard to imagine the scale involved. Could some of the "stars" we are seeing also be galaxies. Maybe just smaller or alternatively further away ? Can a star be distinguished from what might just be a more distant galaxy ?
