Cantilever Deflection: Equation for Uniform Load
The equation for the deflection of a cantilever beam with a uniformly distributed load applied to only a portion of the beam differs from the full beam load equation. For a uniformly distributed load over a length 'a' from the fixed end, the deflection can be calculated using a modified version of the standard equation. The general formula involves parameters such as the load intensity 'w', the length of the beam 'L', the modulus of elasticity 'E', and the moment of inertia 'I'. Reference to the Euler-Bernoulli beam theory provides additional context for understanding beam deflection mechanics. Accurate calculations are essential for structural integrity in engineering applications.
Quickdry135
It's been a while since I've studied mechanics. Would someone remind me as to the equation for the deflection of a cantilever beam with a uniformly distributed load on only a part of the beam? I remember the equation for a load on the entire beam is (wL^4)/(8EI)
thanks.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
