Firing into a industrial boiler
  • Thread starter Thread starter ricphysic
    Boiler Industrial
The discussion centers on heat transfer efficiency in a water tube boiler furnace, specifically comparing the heat from the flame entering the boiler versus the combustion gases from an external combustion chamber. It is noted that the flame itself is merely the light emitted by the combustion gases, which suggests that the combustion gases may play a more significant role in heat transfer. Participants are encouraged to provide feedback or suggest alternative resources for further exploration of the topic. The inquiry seeks to clarify which method of heat transfer is more effective in this context. Overall, understanding these dynamics is crucial for optimizing boiler performance.
ricphysic
Which transfers more heat inside a water tube boiler furnace. The flame entering the boiler, or the combustion gases generated by the flame from a combustion chamber located outside the boiler?
Assume the flame is not impinging any water tube.
Would appreciate any and all feedback…with a brief explanation. Or perhaps you know of a better website where this question could be posted...or reference manual?
Thank you.
The "flame" is just the light caused by the combustion gases.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
