Help: Understand Converges & Diverges w/ Examples for Test
  • Thread starter Thread starter disneychannel
Convergence and divergence refer to the behavior of sequences as they approach a limit or grow indefinitely. A sequence converges if its terms approach a specific value, while it diverges if the terms increase without bound or oscillate without settling. For example, the sequence {1/n} converges to 0, whereas {(-1)^n} diverges. In rational sequences, the dominant terms dictate the convergence behavior; if the denominator's degree is higher, the sequence converges to 0, and if degrees are equal, it converges to the ratio of leading coefficients. Understanding these principles is crucial for solving related problems effectively.
disneychannel
I would really appreciate if someone would explain Converges and Diverges to me since I do not understand them.
For example I do not know what to do in this problem:
(5n4 +1)/(150,348n3 +999)
or problems like this
2,1, (2/3), (1/2), (2/5)
Please help! I have a test tomorrow on this!
Mathematics news on Phys.org
I'm assuming you're talking about convergence or divergence of a sequence, so I'll give rough definitions in that context. A sequence of numbers converges to a limit L if the terms in the sequence get arbitrarily close to L as n gets larger.
The sequence diverges if its terms get larger and larger without bound, or they get more and more negative, or if they never settle on a particular value.
For example, the sequence {1/n} = {1, 1/2, 1/3, 1/4, ..., 1/n, ...} converges to 0. The larger n gets, the closer 1/n gets to zero.
The sequence {(-1)^n} = {-1, 1, -1, 1, ...} diverges.
The sequence {n^2/(n + 500} diverges. The first few terms in this sequence are {1/501, 4/502, 9/503, 16/504,...}
The sequence {2, 1, 2/3, 1/2, 2/5, ...} can also be written as {2/1, 2/2, 2/3, 2/4, 2/5, ...} There are other possibilities, but I would guess that the next term in the sequence is 2/6 = 1/3.
For fractions, you can ignore all but the leading terms when you want to know whether it converges or diverges. So (3x^2 + 2x - 1)/(4x^3 - 3x) converges because 3x^2 / 4x^3 converges.
For the first sequence, note that the quadratic terms increase much faster than non-quadratics, and further you can show that terms of higher powers increase much faster than terms of lower powers. This notion of "higher degree terms dominate the convergence behavior" can be made more precise.
For example, it is easy to show that the sequence (1/n) approaches 0 as n increases without bound. This means that (n/n^2) also does this, and so forth.
It is also easy to see that (n) diverges, and thus so does (n^2/n) and so forth.
(a*n^2)/(b*n^2) and similar forms are obviously just a/b.
Consider (an^2 + bn + c)/(dn^2). Division shows this sequence must be a/d by the simple theorems above.
Now for a full rational sequence: (an^3 + bn^2 + cn + d)/(en^3 + fn^2 + gn + h). Multiply the top and bottom by 1/n, and examine the behavior of each term. Keep doing so until you get to the intuitive conclusion that this sequence converges to a/e.
You can now prove yourself that sequences of rational terms converge to 0 when the denominator is of a higher degree, converge to the ratio of the coefficients of the two highest degree terms when the degree of the numerator and denominator are equal, and diverge when the numerator is of higher degree than the denominator.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-sln2)+e^(-sln3)+e^(-sln4)+... , Re(s)>1 If we regards it as some function got from Laplace transformation, and let this real function be ζ(x), that means L[ζ(x)]=ζ(s), then: ζ(x)=L^-1[ζ(s)]=δ(x)+δ(x-ln2)+δ(x-ln3)+δ(x-ln4)+... , this represents a series of Dirac delta functions at the points of x=0, ln2, ln3, ln4, ... , It may be still difficult to understand what ζ(x) means, but once it is integrated, the truth is clear...
