Flow rate/ Bernoulli's equation
creamypies
ap physics student, on this for the first time
The flow rate of water through a garden hose is 60 cm3/s, and the hose and nozzle have cross sectional areas of 5.1 cm2 and 1.6 cm2 respectively.
(a) If the nozzle is held 11 cm above the spigot, what are the flow speeds through the spigot and the nozzle?
spigot
cm/s
nozzle
cm/s
(b) What is the pressure difference between these points? (Consider the water to be an ideal fluid.)
Pa
I think that it is bernoulli's but I could be wrong
welcome to pf!
hi creamypies! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
Yup, (a) is geometry, and (b) is https://www.physicsforums.com/library.php?do=view_item&itemid=115" (for which you need the speeds from (a)) …
what do you get? :smile:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
