Can Vectors Project Onto an Arbitrary Line?
  • Thread starter Thread starter batballbat
    Vector
All vectors can project onto an arbitrary line, including cases where the vector and line do not intersect and are not parallel, as long as the zero vector is considered a valid projection. For instance, a vector along the x-axis projects to the zero vector on the y-axis. In scenarios involving skew lines, such as a vector along the x-axis and a line defined by the parametric equations x=t, y=t, z=1, the projection remains the zero vector. This demonstrates that the concept of projection is applicable even in non-intersecting, non-parallel situations. Thus, the zero vector serves as a universal projection for vectors in these contexts.
batballbat
can all vectors have projection on an arbitrary line? What if the vector and the line do not intersect and are not parallel (i.e. they cannot lie on the same plane).
Mathematics news on Phys.org
Yes, if you allow the zero vector as a projection. for example, a vector pointing along the x-axis has the 0 vector as its projection on the y-axis.
For an example where "the vectors do not intersect and are not parallel" but lie along skew lines, consider a vector pointing along the x-axis and the line given by the parametric equations x= t, y= t, z= 1. The projection is again the 0 vector.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
