Procedure to compute a multiplicative inverse
dodo
I think I found a procedure (other than the extended Euclidean algorithm) to compute the multiplicative inverse of a number; possibly a simpler method. It goes like this:
***EDIT: Ah, dang. I made a mistake. It will only work for a prime modulus.
Suppose we need to find x satisfying ax \equiv 1 \pmod m, where \gcd(a,m)=1.
We need to use a twisted version of the division algorithm, one that gives us integers q_1, r_1 such that m = q_1 a - r_1 (note the minus sign), with r_1 as small as possible. (So q_1=\lfloor m/a \rfloor+1.) Hence, q_1 a \equiv r_1 \pmod m.
Now, if r_1=1 we would be done: q_1 would be the multiplicative inverse we are looking for. So suppose it is not yet. But... if we had the multiplicative inverse of r_1, then we could multiply it to q_1 to get our solution.
So... rinse and repeat: find the inverse of r_1 (a smaller number, now). Note that \gcd(r_1,m)=1[/size] (<-- only guaranteed when m is prime!), so that the procedure can in fact be repeated.
Using the same procedure repeatedly, we obtain a sequence of divisors q_1, q_2, ..., q_n until r_n=1; then the multiplicative inverse of a is the product of all q_1, q_2, ..., q_n (reduce it modulo m if you wish).
Here is a worked example. Suppose you want the inverse of 1234567 modulo 3257269. We proceed as follows:
3257269 = 3 . 1234567 - 446432
3257269 = 8 . 446432 - 314187
3257269 = 11 . 314187 - 198788
3257269 = 17 . 198788 - 122127
3257269 = 27 . 122127 - 40160
3257269 = 82 . 40160 - 35851
3257269 = 91 . 35851 - 5172
3257269 = 630 . 5172 - 1091
3257269 = 2986 . 1091 - 457
3257269 = 7128 . 457 - 227
3257269 = 14350 . 227 - 181
3257269 = 17996 . 181 - 7
3257269 = 465325 . 7 - 6
3257269 = 542879 . 6 - 5
3257269 = 651454 . 5 - 1
The end was agonizing, but here we are: the inverse is 3 . 8 . 11 . 17 . 27 . 82 . 91 . 630 . 2986 . 7128 . 14350 . 17996 . 465325 . 542879 . 651454... or 1127070 (mod 3257269).
On a computer, the product could be accumulated modularly, so there is really no need to handle too large numbers.
One can always break down large numbers via the modulo function and recombine the results with the Chinese remainder theorem. This is not new.
