Do DIFFERENT observers see a DIFFERENT force on accelerating body?
skunkswks
Hi, my question in full; Do DIFFERENT observers (in different INERTIAL reference frames) see a DIFFERENT force (Magnitude specifically) acting on an accelerating body?
I believe yes . Because... :
ƩF = d(p)/d(t) = m*a + v * d(m)/d(t)
where m = m0/√(1-v^2/c^2)
where v is different for every observer in a different inertial reference frame?
Hence, people in different reference frames 'see' a different force
Hence they also record different measurements for acceleration of the body? or does the acceleartion always agree and they record different measurements for the mass of the body w.r. to their own reference frame?
How correct is all this?
Thank you in advance.
You are correct on both accounts, both force and acceleration are frame-variant in relativity. There are specific Lorentz transforms for each of them.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
