Necessity of End time in analysis Setting
  • Thread starter Thread starter Total_Damage
    Analysis Time
The necessity of setting an end time in analysis settings is crucial for capturing the deformation of a target by a projectile traveling at 840 m/s over a distance of 22 m. It is suggested to set the initial position of the projectile slightly closer to the target, around 0.1 m, and to use an end time of 0.1 seconds or less to observe the impact. The choice of material models for both the projectile and target is important, particularly regarding the need for modeling penetration and fracture. The discussion also touches on the differences between Ansys Autodyn and Ansys Workbench>Explicit>Autodyn, as well as inquiries about materials that behave like liquids under pressure but solidify. Understanding these aspects is essential for accurate simulation results in Ansys.
Total_Damage
Dear Sir,
Could anyone tell me, what is the Necessity of End time in analysis Setting.
I just want to calculate the Deformation in the target by the Projectile with the velocity of 840m/s. here i want the result by Releasing the projectile in the distance of 22m. Here only I'm having the problem.
1. How to set the distance traveled by the Projectile. i prepared the model by using Pro-E and imported to Ansys. Using version 14.
2. How to get the Deformation on the target?
3. Could anyone is having tutorial in Ansys Autodyn?
Pls Pls Help me from this things??/////
I think you can just set the initial position of the projectile to be some arbitrarily small distance from the target, like .1m instead of 22m. Then, give it an initial velocity of 840m/s. Setting your endtime to .1s or less should capture everything you want to see.
It would seem to me that the more important questions are:
What Ansys material model are you using for the projectile and the target? Are you using solid elements? Do you need to model fracture and penetration?
Thank you afreiden,
I'm using to solve this Problem in Ansys Workbench>Explicit>Autodyn3D. Yes I'm using Different material, Projectile is having two and target is one solid material. For material i was selected from Explicit material>Projectile-(Tungsten at the tip and and for the base Steelv230, For target applied RHA. And i need Penetration.
and one thing have to know, What is the difference Between ansys Autodyn and Ansys Workbench>Explicit>Autodyn.
Need your Reply for this too, While speaking with one Prof, He said that one material, That is in nature liquid, but when it subjected to pressure it wll become solid state. do u know such a material. pls help me, and waiting for your reply...
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
