EM field due to a long wire submitted to an AC current
To establish the equations for the magnetic field B(t) and electric field E(t) along the X axis due to a long wire carrying an alternating current, the assumption of cylindrical symmetry and uniform current along the wire's length is crucial. The distance from the wire should be small compared to the wavelength of the alternating signal to simplify calculations. Utilizing Maxwell's equations is essential, and considering retarded potentials may also provide insights into the problem. Neglecting the time-dependence of the current can yield a good approximation under these conditions. This approach will help in accurately determining the electromagnetic fields generated by the wire.
jfgobin
Hello there,
I am having a real stupid moment.
In the space XYZ, a long wire is along the Y axis and is submitted to an alternating current I_{0}\sin \omega t. I am trying to establish the equations for the B(t) and E(t) fields along the X axis.
I assume that the distance to the cable is small in regard to the cable length and that the cable length is small in regard to the wavelength of the alternating signal, so the cable can be seen as having a uniform current along its length. I am pretty sure the problem will have a cylindrical symmetry.
Besides the "use Maxwell's equations", any hint to attack this problem?
Thanks to all!
"use retarded potentials"?
If the distance to the cable is small compared to the wavelength of the alternating signal (if not, the finite cable length is a problem!), you can neglect the time-dependence of the current to get a good approximation.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
