Finding the limit of the equation
  • Thread starter Thread starter shwanky
    Limit
shwanky
Evaluate the limit if it exists
\lim_{x\to 0} \frac{1}{x}-\frac{1}{|x|}
1) \lim_{x\to 0} \frac{1}{x}-\frac{1}{|x|}
2a) \lim_{x\to 0} \frac{1}{x}-\frac{1}{x}
2b) \lim_{x\to 0} \frac{1}{x}-\frac{1}{-x}
3a) \lim_{x\to 0} 0 = 0
3b) \lim_{x\to 0} \frac{1}{2x}
4)\lim_{x\to 0} \frac{1}{2}x
5)(\frac{1}{2})0 = 0
Did I do this correctly?
The limit is quite different if you approach zero from the negative direction or the positive direction. Split it into these two cases as I think you have tried to do, but 1a) 1b) 2a) 2b) etc is not the clearest way to express this. But finally 1/(2*x) is not equal to (1/2)*x. That's BAD.
Well, you didn't do it right as it doesn't exist.
1/x goes to -\infty as x->0 from the left. but -1/|x| is also going to -\infnty.
Use the sequence criterion of limits for a more formal proof.
Also note 1/x + 1/x is not 1/2x.
Thanks, I kind of figured it was wrong. I'm still a little shakey on limits. If it's a problem that I can factor and substitute, I'm okay, but my professor didn't clearly explain this in class. I can usually see that the limit doesn't exist, but I don't know how to state it. Should I just take the + and - limits and show that they don't approach a common point on an open interval as ZioX did?
Yes. The limits from the two sides are different. So there is no common limit. So the limit doesn't exist.
OMG! I can't believe it was that simple... :(
Define x_n=-1/n. This is a sequence converging to 0. But 1/x_n-1/|x_n|=-2n which doesn't converge to anything. Therefore 1/x-1/|x| has no limit as x tends to zero.
This is the sequencial criterion for limits. A function f converges to L as x converges to a iff for every sequence x_n converging to a has the property that f(x_n) converges to L.
For the limit to exist, \lim_{x\to 0} \frac{1}{x}-\frac{1}{|x|} =\lim_{x\to 0^{+}} \frac{1}{x}-\frac{1}{|x|} = \lim_{x\to 0^{-}} \frac{1}{x}-\frac{1}{|x|}
However we can see that \lim_{x\to 0^{+}} \frac{1}{x}-\frac{1}{|x|}=0 but \lim_{x\to 0^{-}} \frac{1}{x}-\frac{1}{|x|} = \lim_{x\rightarrow 0} \frac{-2}{x}, which are obviously not the same.
\frac{1}{2x}\ne \frac{1}{2} x!
And, technically, you should say lim_{x\rightarrow 0^+} and lim_{x\rightarrow 0^-} but that isn't as bad as the howler above!
