Identify Lighter Balls Weighing on Christmas Tree
  • Thread starter Thread starter dipinsingh
    Balls
The discussion revolves around a logic puzzle involving a Christmas tree adorned with six balls—two blue, two red, and two white—where each color has one heavier and one lighter ball. The objective is to identify the lighter balls using a balance scale in two weighings. The first weighing involves placing a white and a red ball on one side and a blue and a white ball on the other. If the scales balance, one colored ball is heavy and the other is light, leading to further testing to identify which is which. If the scales tip, the heavier ball is the one on the lower side. The second weighing involves comparing the two colored balls against the two white balls to determine their weights based on the scale's response. This systematic approach effectively narrows down the identities of the lighter balls.
dipinsingh
Weighing...
On a Christmas tree there were two blue, two red and two white balls. All seemed the same, however in each colour pair one ball was heavier. All three lighter balls were the same weight, just like all three heavier balls.
Using a pair of scales twice, identify the lighter balls.
Put in one scale a white and a red ball and in the other scale a blue and the other white ball.
If the scales are even, this means that one of the colored balls is heavy and the other is light. Weight one against the other to determine which is which. The light white ball is the one that was in the same scale with the heavy colored ball.
If the scales are not even, you know already that the heavy white ball is the one in the down scale. The colored balls may be both heavy, both light or the one in the down scale is heavy and the other is light.
Put the two colored balls in one scale and the two white balls in the other. If the colored balls go down is because they are both heavy, if they go up, both are light, if the scales are even, the one that was down in the first weighting is heavy and the other is light.
U R Right.
Just ONCE, I wanted to see a post titled Status Update that was not a blatant, annoying spam post by a new member. So here it is. Today was a good day here in Northern Wisconsin. Fall colors are here, no mosquitos, no deer flies, and mild temperature, so my morning run was unusually nice. Only two meetings today, and both went well. The deer that was road killed just down the road two weeks ago is now fully decomposed, so no more smell. Somebody has a spike buck skull for their...
