Magnetic Induction In terms of Creating Charge
Charging a battery through magnetic induction is theoretically possible, but impractical for small applications like powering street lights. Traffic lights utilize induction for sensing vehicles rather than as a power source. To generate sufficient energy, a significant physical movement or a large number of coils would be necessary, which may not be feasible given the distance and positioning of the coils. Calculations indicate that the voltage generated would be too low to power typical light bulbs effectively. Overall, while innovative, the concept faces substantial challenges in energy generation and practicality.
marias3
Hi,
I'm an industrial designer and I was wondering if there is a way to charge a battery through magnetic induction. I have heard that the way some stop lights work is there are coils below the road, and when the steel body of a car goes over it, it creates a change in charge in those coils. Is there a way a similar idea could be used to charge small batteries?
thanks
I would think that it is possible however it is not practical.
The traffic lights are using the induction as a sensor, and rely on the moving car, and not as a power source.
If you wanted to charge a battery by the same principal, say in a lab, you would have to physically move something to create that induction, for example youself, or maybe a motor moving a magnetic core through the solenoid, which in turn uses power from another source.
So why not just use the power to charge the battery straight from the main source of power?
Hope that helps
I was hoping to rig up some sort of device that could power the pedestrian/street lights via the traffic that goes over them. Also I was hoping this would be a cheaper solution than using solar power in areas where there might not already be power lines. is this feasible?
If you do some quick calculations with Faradays law you will start to see the problem. A very small voltage would be created across a winding under the road, due to a number of things; The car being realitivlty far from the coil, the coil is underground, cars may not come past so energy would need to be stored. So you would not get enough power out of one coil.
If a lightbulb is ~75W or so, you are not going to create enough energy to run these lightbulbs all night. At a guess you would need probably 20-30 large coils, under a busy road were the cars are going >80km, to start to even get the energy you need. Just a guess though I didn't do the calculations :-)
Who knows, maybe a smart idea will get around this problem...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
