Bluetooth Receiver: Class 1 vs Class 2 for Senior Project
  • Thread starter Thread starter factorial
    Bluetooth Receiver
Choosing between the Class 1 ESD1000 and Class 2 ESD200 Bluetooth receivers for an elevator project hinges on range and antenna considerations. The ESD1000, which operates on Bluetooth v2.0 + EDR, lacks an onboard antenna, while the ESD200 includes one but uses the older v1.2 version. The ESD1000 is cheaper, possibly due to the absence of an antenna or lower production demand. For optimal performance in an elevator shaft, directional antennas are recommended to enhance signal reliability, especially given the limited range of the ESD200. Overall, the ESD1000 may be more suitable if paired with a good external antenna for better signal strength.
factorial
I'm not sure whether to use this:
Class 1
http://www.kanda.com/products/Sena/PARANI-ESD1000.html
or
Class 2
http://www.kanda.com/products/Sena/PARANI-ESD200.html
I'm planning to use it in an elevator for a senior project and I would like some suggestions or advice on which to choose. The ESD1000 says that an antenna isn't included with or on the chip and it uses v2.0 + EDR. However, the ESD200 chip says that it has an on-board antenna and it uses v1.2. Is it necessary to have the antenna because I know the ESD1000 has the newer version of Bluetooth but the lack of antenna concerns me. Also, why is the ESD1000 cheaper than the ESD200?
I've used ESD1000 before without the antenna and it's fine. Depends on how far you want to be able to go with the elevator I suppose, 100 meters or 1,000 meters. Not sure about the price difference, it could be because the antenna is included, or it could be because they just don't make the ESD200 as much anymore. Supply and demand, and all that jazz.
Edit: Whoops, turns out I used ESD100 before, not 1000 (only off by one logarithmic scale)
I see. Thanks for the response. Anyone else have second opinions or more input to add in please?
How tall is the elevator shaft? That 30m range advertised for the unit with the PCB antenna is not very far, and may not be all that reliable even at 30m. An elevator shaft would generally call for directional antennas, to maximize your SNR and comm reliability. So the unit with the SMA antenna connector would seem to be the best choice, and you will want to find/make good directional antennas. You could make 3-element Yagis, for example, to get some reasonable gain in the axis of the elevator shaft.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
