Why Do Stars and Galaxies Keep Spinning?
Stars and galaxies maintain their spin due to the principle of angular momentum, which states that an object in motion will remain in motion unless acted upon by an external force. Large celestial bodies, like a spinning ice globe, will continue to spin even if they change state, such as melting into water, as long as no external torque is applied. This means that once an object starts spinning, it will keep spinning indefinitely without the need for continuous energy input. The discussion emphasizes that the conservation of angular momentum is key to understanding why these macro objects do not stop spinning. Overall, the mechanics of spin in celestial bodies are governed by fundamental physical laws.
samsara15
It takes a continuous input of energy to spin, otherwise things would fly apart or stop spinning. So why do large macro objects spin, and continue to spin?
Ever heard of angular momentum?
Consider the following situation. A spinning globe of pure ice, say a small meteor, a meter in diameter, spinning around its own axis, approaching the sun, so that as it approaches the sun, it melts. Are you saying that the globe of ice will continue to remain a globe of water, still a meter in diameter, even after it melts?
Yes and it will still spin with the same angular momentum
There's your problem right there. It doesn't. Unless an external torque is applied, once an object starts spinning, it stays spinning.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
