Al68 said:
It seems like you're suggesting that something physically happens to the clocks. This is simply not the case.
"If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B by .5tv^2/c^2 (up to magnitudes of fourth and higher order), t being the time occupied in the journey from A to B.
It is at once apparent that this result still holds good if the clock moves from A to B in any polygonal line, and also when the points A and B coincide.
If we assume that the result proved for a polygonal line is also valid for a continuously curved line, we arrive at this result: If one of two synchronous clocks at A is moved in a closed curve with constant velocity until it returns to A, the journey lasting t seconds, then by the clock which has remained at rest the traveled clock on its arrival at A will be a .5tv^2/c^2 second slow. Thence we conclude that a balance-clock at the equator must go more slowly, by a very small amount, than a precisely similar clock situated at one of the poles under otherwise identical conditions."
In the first paragraph Einstein states -
"...on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other ."
In other words, according to
Einstein,
something physically happens to the moving clock. It is no longer synchronized with the inertial clock.
In the third paragraph Einstein states -
"...a balance-clock at the equator must go more slowly, by a very small amount, than a precisely similar clock situated at one of the poles."
Einstein, something is physically happening to to the equatorial clock - it is ticking over at a slower rate than the polar clock ("under otherwise identical conditions.")
Perhaps it is
your opinion that nothing physically happens to either of the clocks however it is
Einstein's opinion to which my posting applies!
Al68 said:
And Einstein's 1918 paper does not claim that the time dilation is not reciprocal between inertial frames. It is simply a resolution taking the accelerated frame into account during the turnaround. During each inertial leg, each clock runs slow as observed from the other frame. Only during the turnaround acceleration, the Earth's clock runs fast as observed from the accelerated frame.
When the clock in Einstein's 1918 paper decelerates and comes to a stop it is analogous to Einstein's section 4 depiction -
"If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B."
Having come to a stop (ergo then being in the same reference frame as clock B) clock A can be synchronized with clock B then having accelerated and moved to B's location A will be found to lag behind B on the basis that it must 'go more slowly' (i.e. tick over at a slower rate) than the inertial clock.
According to your depiction that "...during the turnaround acceleration, the Earth's clock runs fast as observed from the accelerated frame." the astronaut must be of the opinion that something has
physically made the Earth clock run
faster than it did
before he started accelerating.
Not only is the Earth clock, in his opinion, running fast - time
itself, for the Earth must also be 'running fast'. Earth clock seconds, minutes, hours and days 'have' contracted hence the planet would, whilst he is accelerating, be spinning faster on its axis than it was before he started accelerating!
The claim that, during the turnaround acceleration, the Earth clock runs fast is usually accompanied by the claim that when the astronaut stops accelerating Earth time resorts to its normal (some insist slower) rate so at the very instant that the astronaut takes his foot off the gas pedal the Earth's faster axial spin
immediately reverts to normal! No gradual slowing down but
immediate return to normal!
And
it's never a matter of opinion what any clock reads in any frame in SR. Every observer will agree on the facts. No clock is running slower than another in any absolute sense. Which clock runs slower than the other depends on which frame the observation is made from. No observer in any
inertial frame ever observes a clock in relative motion to run faster than his own, or his own clock to run slower than one in relative motion.
Al68 said:
This is true in Einstein's 1918 paper as well. It is only with respect to the accelerated frame of the ship during turnaround that a clock in relative motion runs fast compared to a clock at rest in that frame, and that's not an inertial frame. During all inertial motion, in each frame, the clock in motion runs slow compared to the clock at rest in that frame. This is reciprocal time dilation.
In Einstein's section 4 he points out that, in each example, when clock A is compared with clock B it is found that A lags behind B.
Having, during his trip, 'determined' that B is, as you say, running slow compared to his clock that is at rest in his frame he arrives at B's location to find that B does not lag behind (having 'run slower' than) his clock but that his clock lags behind B.
I am of the opinion that your comment that an astronaut accompanying clock A in Einstein's depictions (of clock A initially accelerating toward clock B) would see clock B 'running faster' is
only as a result of Doppler shift however he sees almost precisely the same amount of Doppler shift when he stops accelerating as he did at the very instant that he removes his foot
from the gas pedal.
There is, I suggest,
nothing in special theory which shows that
any action performed by the astronaut - accelerating, decelerating, moving toward or away from another clock at any velocity - will have a
physical affect
on that other clock - only on what it
appears to be doing.
The idea (during the astronaut's period of acceleration following turn around) that the stationary clock incurs time
contraction (i.e. 'is' ticking over at a
faster rate than it was before he accelerated) was, for Einstein, an anathema and it it is
his depictions to which I refer
not interpretations arrived at
by anybody else.
