Simple Precalculus: Average rate of change
To find the average rate of change of g(x) = 1/x from x = 1 to x = a, the formula used is (g(a) - g(1)) / (a - 1). The calculations yield g(1) = 1 and g(a) = 1/a, leading to the expression ((1/a) - 1) / (a - 1). The correct simplification reveals the average rate of change as -(1/a). The discussion highlights the importance of careful algebraic manipulation and recognizing basic rules to avoid errors in problem-solving.
DarrenM
Find the average rate of change:
g(x)=1/x; x = 1, x = a
(f(b)-f(a))/(b-a) = Average rate of change
I've spent far too much time on this problem, but I know I'm making a stupid error and I just can't pin it down. So far, the steps I'm pretty confident about:
g(1) = 1/1 = 1
g(a) = 1/a
Average rate of change = ((1/a)-1)/(a-1)
According to the book the answer is -(1/a)... but I'm just not seeing it.
1/a-1 = (1-a)/a :wink:
Yea, got it now. It was just as ridiculous an oversight as I had originally thought. I kept getting to the point in the problem where I had (1-a)/(a(a-1)) and going, "Oh, I can't divide those binomials!" Factor out a -1 from the numerator, cancel out the resulting binomial with the denominator and there's the answer... staring me right in the face. I'm rather embarrassed that I had so much trouble with such a simple problem, and that I forgot such a basic rule. Thanks for the help.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
