Is there software that can accurately display the frequency of audio input?
Software options for visualizing audio input frequencies include "Spectran," which accurately displays frequencies up to 15 kHz. Unlike traditional tuners that struggle with frequencies above 1 kHz, Spectran offers a "waterfall" display that shows a moving spectrum and identifies the strongest signal's frequency. Users can measure other frequencies by hovering the mouse pointer over them, though the display uses standard-sized text rather than large numbers. For those needing to measure higher frequencies, a prescaler can be utilized.
ymhtr
Is there any software that shows the frequency of audio input as digital display?Tuner softwares can not read frequencies above 1 khz regularly.The following link is an example of a tuner screenshot. http://www.techmind.org/audio/mustun.gif
Computer science news on Phys.org
There is a good program called "Spectran" which will give you a frequency up to about 15 KHz.
You could use a prescaler if you wanrted to go higher.
The display is mainly a "waterfall" which is sort of a moving spectrum display but it also gives the frequency of the strongest signal very accurately.
You can measure the frequency of other signals in the display just by putting your mouse pointer on them.
It gives the frequencies but not in big red numbers. It is just normal size printing.
Easy to see, though.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
