The current northern hemisphere cold spell
The current cold spell in the northern hemisphere is primarily attributed to an extreme negative phase of the Arctic Oscillation (AO), which weakens the polar vortex and allows Arctic air to move southward. This phenomenon results in warmer Arctic temperatures while causing colder conditions in the middle latitudes, particularly in Europe and North America. The AO index recently reached its most negative value since 1950, highlighting the significance of this climatic shift. Additionally, blocking patterns in the atmosphere contribute to persistent weather conditions, further influencing temperature anomalies. Understanding these dynamics is crucial for comprehending the unusual weather patterns experienced this year.
dorlomin
I have heard a couple of different explations from the jet stream moving south to the alantic dipole shifting. Others are saying that the gulf stream has temporarily shifted towards greenland.
Does anyone have a clear idea of what is going on and more important why there has been this shift in weather patterns this year?
Here is an easy to understand explanation of what caused the cold snap.
http://www.weather.com/outlook/weather-news/news/articles/why-so-cold-greenland-block_2010-01-11
There Arctic Oscillation is in an extreme negative phase. This makes for a weak polar vortex and allows the Arctic air to descend to lower latitudes. This also means that Arctic temperatures are higher then normal.
http://nsidc.org/arcticseaicenews/
Negative phase of the Arctic Oscillation
These regional contrasts in temperature anomalies resulted from a strongly negative phase of the Arctic Oscillation (AO). The AO is a natural pattern of climate variability. It consists of opposing patterns of atmospheric pressure between the polar regions and middle latitudes. The positive phase of the AO exists when pressures are lower than normal over the Arctic, and higher than normal in middle latitude. In the negative phase, the opposite is true; pressures are higher than normal over the Arctic and lower than normal in middle latitudes. The negative and positive phases of the AO set up opposing temperature patterns. With the AO in its negative phase this season, the Arctic is warmer than average, while parts of the middle latitudes are colder than normal. The phase of the AO also affects patterns of precipitation, especially over Europe.
The phase of the AO is described in terms of an index value. In December 2009 the AO index value was -3.41, the most negative value since at least 1950, according to data from the NOAA Climate Prediction Center.
The Greenland block is another name/aspect of a negative Arctic Index.
It produces colder temperatures in Europe and the Eastern Half of North America
while producing warmer temperatures over the Arctic.
It is basically a fickle phenomena. No trend in intensity has been found, but it has
tended to be more positive than negative since the 1970's. So, when it is
negative, people in North America and Europe tend to notice it.
Interesting that it recently hit a record since 1950.
See http://www.ipcc.ch/pdf/assessment-report/ar4/wg1/ar4-wg1-chapter3.pdf" Blocking:
Blocking events, associated with persistent high-latitude
ridging and a displacement of mid-latitude westerly winds
lasting typically a week or two, are an important component of
total circulation variability on intra-seasonal time scales. In the
NH, the preferred locations for the blocking are over the Atlantic
and the Pacific (Tibaldi et al., 1994), with a spring maximum
and summer minimum in the Atlantic-European region (Andrea
et al., 1998; Trigo et al., 2004). Observations show that in the
Euro-Atlantic sector, long-lasting (>10 day) blockings are
clearly associated with the negative NAO phase (Quadrelli et
al., 2001; Barriopedro et al., 2006), whereas the blockings of 5
to 10 day duration exhibit no such relationship, pointing to the
dynamical links between the life cycles of NAO and blocking
events (Scherrer et al, 2006; Schwierz et al., 2006). Wiedenmann
et al. (2002) did not find any long-term statistically signifi cant
trends in NH blocking intensity.
And also the http://nsidc.org/arcticmet/patterns/arctic_oscillation.html"
Over most of the past century, the Arctic Oscillation alternated between its positive and negative phases. Starting in the 1970s, however, the oscillation has tended to stay in the positive phase, causing lower than normal arctic air pressure and higher than normal temperatures in much of the United States and northern Eurasia.
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
