Is Life an Anti-Entropic Zone in the Fabric of Space/Time?
The discussion explores the concept of the non-linear fabric of space/time as an anti-entropic zone, suggesting that life phenomena can emerge and duplicate within this framework. It posits that thermodynamic and Shannon entropy are conceptually equivalent, linking quantum-phase entanglement to thermodynamic processes. The conversation emphasizes that the laws of physics are time-independent organizing principles, implying that randomness is an illusion. It further argues that complexity can arise from simplicity in fractal-like curved space/time zones, fostering optimal environments for life. Ultimately, the discussion highlights the potential for temporary order to emerge from disorder, contributing to the evolution of complexity in living systems.
Lama
Can we say that non-linear fabric of space/time (n_Dim fabric that is curved toward n+1_Dim)
is an anti-entropic zone?
And if so, can we understand life phenomena as an anti-entropic zone that can duplicate itself?
Astronomy news on Phys.org
My hypothesis is that thermodynamic entropy is actually the recombinative effects of quantum-phase entanglement in the thermodynamic direction/arrow of time.
This is also known as Shannon entropy:
http://www.gulizk.com/fizik/holographic.html
Thermodynamic entropy and Shannon entropy are conceptually equivalent: the number of arrangements that are counted by Boltzmann entropy reflects the amount of Shannon information one would need to implement any particular arrangement. The two entropies have two salient differences, though. First, the thermodynamic entropy used by a chemist or a refrigeration engineer is expressed in units of energy divided by temperature, whereas the Shannon entropy used by a communications engineer is in bits, essentially dimensionless. That difference is merely a matter of convention.
Time is a process of flux. Flux is the rate that that a
quantity passes through a fixed axis or boundary. Resonate fluxing via position/momentum quantized feedback oscillations. Universal Resonance.
(ict)^2 + (ct)^2 = 0
f(z)
f[f(z)]
f{f[f(z)]} ... f_0{...[f_n]}
1. With a little earnest thought, one realizes that the concept of randomness is logically absurd.
2. The laws of physics are time independent. They hold for all frames of reference.
3. Also, even if ...physical randomness is true, physical randomness would not exist without time, or "change" - from one state to the next.
4. If the physical laws are time independent then the physical laws, by definition, did not arise "randomly".
5. The laws of physics are a set of organizing principles.
6. The only true example we have of an organizing principle is that of a "MIND"
7. The universe came from a MIND.
a) Anti-entropic zone is related to infinitely many things, where the base principle is the optimal conditions to create order out of disorder.
b) Form general point of view, life is based on (a) and I think that places where many levels of internal fractal-like curved space/time are found, are maybe the zones where complexity can be flourished out of simplicity.
In this multi-leveled fractal-like curved space/time zones, there is a good chance to find a rich enough chemistry, which can be used as an optimal environment for life phenomena development.
If we measure the life phenomena lost of energy by insufficient heat, we find that at this stage, it creates more disorder then order.
But we cannot ignore the fact that it is really can create a temporary zones of order out of disorder, and then duplicate them and make them more and more complex, during the evolution process.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
