Throwing a dart from a roof - Velocity
  • Thread starter Thread starter mybrohshi5
    Velocity
A dart thrown horizontally from a rooftop has a flight time of 2.0 seconds and lands at a 53.1-degree angle with the ground. The initial vertical velocity is zero, and the final vertical velocity after 2 seconds is calculated to be 19.6 m/s using the equation Vf = Vi + at. The horizontal component of the final velocity (Vfx) is determined using the tangent of the angle, leading to a value of 14.7 m/s. This calculation confirms the speed at which the dart was thrown. The solution process is validated by the participants in the discussion.
mybrohshi5
A dart is thrown horizontally from a buildings rooftop. The dart's time of flight is 2.0 s. The dart sticks in the ground such that it makes a 53.1 degree angle with the ground.
With what speed was the dart thrown?
I am studying for my final and i do not get this problem from one of my previous tests.
The answer is 14.7 m/s and i have no idea how to get it. Can anyone point me in the right direction.
Thank you :)
Well if it is throw horizontally, then the initial vertical velocity is zero right? Using an equation of motion, what would be final vertical velocity when t=2?
Is the final vertical velocity when t=2 just 19.6 m/s
I got that from
Vf = Vi + at
oh so then from that the x component of the Vf will be the same as the velocity initial correct?
so
tan(53.1) = 19.6 / Vfx
Vfx = 14.7 m/s
Does that seem right?
Yes that looks correct.
Yay! thank you very much :)
