How Does a Frictionless Pulley Influence Acceleration in Connected Masses?
The discussion centers on how a frictionless pulley affects the acceleration of two connected masses. The presence of rotational inertia in the pulley requires torque for acceleration, which is factored into the net force equation as I/r^2, representing the effective mass of the pulley. Participants clarify that torque does not consume force but rather influences the system's dynamics similarly to how mass does. The rotational inertia formula, I = MR^2 / 2, is referenced, but participants emphasize deriving the equations rather than relying on shortcuts. Overall, the conversation enhances understanding of the relationship between torque, rotational inertia, and acceleration in connected mass systems.
123yt
Pretend there are two accelerating masses connected to a massless string with a frictionless pulley between them. How can the frictionless pulley (Rotational inertia and radius given) affect acceleration in any sort of way?
Also, why is the net force equal to Acceleration * (Mass of two blocks + I/r^2)? I understand the part with the two blocks, but not with the I/r^2.
The pulley has rotational inertia and thus requires a torque to accelerate it.
You can think of I/r^2 as the effective mass of the pulley. But that equation is a bit of a short cut. Rather than use it directly, derive your own version by applying Newton's 2nd law to each mass and the pulley itself.
But torque is just a measure of how much a force causes an object to rotate. It doesn't "use up" any force to rotate it, right?
The rotational inertia of the pulley is I = MR^2 / 2, so shouldn't the mass be M = 2 * I / R^2?
It "uses up" force in a manner similar to how pushing a mass "uses up" force.
No. If you derive the equation, you'll see where that I/R^2 term comes from. (No reason to treat the pulley as a uniform disk.)
Alright, thanks for the help. I think I understand torque and rotation a little better now.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
