Salt Formation: Attraction of Sodium & Chlorine
The discussion centers on the nature of sodium chloride (NaCl) and its ionic bonding. Sodium (Na) carries a positive charge, while chlorine (Cl) carries a negative charge, resulting in a neutral compound when combined. However, NaCl does not exist as isolated pairs of Na+ and Cl- ions; instead, it forms a crystal lattice structure where each sodium ion is surrounded by six chloride ions and vice versa. This arrangement is stabilized by strong ionic attractions among the millions of ions in the lattice. The presence of a strong dipole moment and higher multipole moments in NaCl contributes to the attraction between the ions, further explaining the stability and formation of the salt crystal. Visual aids are provided to illustrate the crystal structure of NaCl.
neginf
Is the combination of an positive sodium with a negative chlorine neutral ?
If so, what attracts and holds together other sodiums and chlorines to make a grain of salt ?
Chemistry news on Phys.org
Even though a hypothetical molecule NaCl is neutral, it has a strong dipole moment and higher multipole moments which lead to a strong attraction of the molecules which can serve as an alternative explanation of how the crystal is formed.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
