How are Cepheids used to measure distances?
  • Thread starter Thread starter Mooky
    Measure
Cepheid variables are used to measure astronomical distances due to their predictable relationship between brightness and pulsation period. By measuring the period of a Cepheid, astronomers can determine its intrinsic brightness. This intrinsic brightness is then compared to its apparent brightness to calculate the distance using the inverse square law. Historically, the lack of nearby Cepheids for parallax measurement posed challenges, but advancements like the Hubble Space Telescope have improved distance measurements. Currently, there are 273 known Cepheids suitable for this method, with more expected from future missions like Gaia.
Mooky
Hello,
I've read about this in four different textbooks and in several websites, but I still don't get it: how are Cepheids used to measure distances? I understand that Cepheids are stars whose brightness varies periodically; that the longer their period, the brighter they are; and that different Cepheids have different brightness and periods.
But, how is that used to measure distances?
Thanks,
M
Astronomy news on Phys.org
Note that the longer the period, the higher their intrinsic brightness. So you measure the period, and then from the relation between period and intrinsic brightness, you now know their intrinsic brightness - that is how bright they really are. Then you measure their apparent brightness - that is how bright they appear. Because of the inverse square law, if we have two objects of the same intrinsic brightness at two different distances, the one further away will appear fainter, just like with two identical street lights - the one further away will appear fainter. So if I know the intrinsic brightness and the apparent brightness, I can calculate the distance. Mathematically, the relation between the two is given here:
http://en.wikipedia.org/wiki/Magnitude_(astronomy)
That explains nothing, mate. They would need a Cepheid close enough for parallax measurement to use as a standard first.
In fact, for many years, this point was the weakest link in the astronomical distance scale, since no Cepheids were close enough to use parallax to measure their distance. So historically other methods were used to get the distance to the nearest Cepheids and calibrate the relationship. Uncertainties in the calibration of the Cepheid relationship led to several re-assessments of the size of the universe. Try reading this:
http://en.wikipedia.org/wiki/Cosmic_distance_ladder
However, this is no longer an issue, since the Hubble space telescope was now able to measure the parallax of Delta Cephei, the prototypical cepheid. See this:
http://en.wikipedia.org/wiki/Delta_Cephei
And there now 273 such objects. There should be many more when Gaia launches.
Thank you, phyzguy. I wish textbooks were as clear and concise as you are.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
