Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #10,591
What a surprise (or more precisely - Quelle surprise!)
Removal of reactor fuel won't start until 2021
http://www.yomiuri.co.jp/dy/national/T110711004878.htm"
I hope this forum (and this thread) are still open when they finally get into the reactors and work out what happened. But that day is a long way away yet.
  • #10,592
If anything, that schedule seems very ambitious. Seen that it took a decade for the TMI reactor fuel to be removed, it would be surprising if this much larger and more complicated accident took a similar amount of time. Afaik, there is no effective way to decontaminate concrete, simply because the radioactive material will have infiltrated deep beyond the surface, helped by the natural aging of the concrete as well as the fissures created by the earthquake and the explosions. So just approaching the lower levels of the reactors to start that part of the cleanup will be a major challenge. Imho, the site will take decades to remediate.
More to the point, once the emissions from the site have been capped, further cleanup work will be very expensive, not only in financial but even more so in human terms, with zero economic reward. Japan is saddled with a massive dead weight loss project because of this disaster.
These costs may be so large that industry is forced to shift to smaller reactors that fail somewhat more gracefully, because no country can afford these consequences.
  • #10,593
joewein said:
If all of it had left the RPV, the RPV bottom temperatures would not respond to the water flow because there would be no heat source to interact with the water flow, even more so if all of it had not only left the RPV but also the containment.
I've argued this several times. You don't have RPV bottom temperatures if corium melted out the bottom of the RPV. You don't have temperatures at all if the bottom of the RPV ever reached or exceeded 1000C. The thermocouples and their leads would have melted off long before the RPV failed.
  • #10,594
True, but if that were the case, there would not be readings that fluctuate with the volume of water injected.
  • #10,595
You may be assuming a complete failure of the vessel bottom which may not have happened. The instrument and CRDM penetrations of the vessel are more likely to have failed first allowing corium to exit the vessel. The thermocouples in US plants are qualified to at least 2300 degrees F per USNRC Regulatory Guide 1.97.
  • #10,596
Perhaps you are thinking that if the corium melted its way out of the RPV, all of the bottom would have been heated to 1500 deg C (melting point of steel) to create an exit path. I don't think that's necessarily the case. In a BWR the control rods are inserted through the bottom of the RPV. If the core melts inside the RPV, corium could flow into the control rod channels and escape from below there without having to take out the entire bottom of the RPV. Therefore in my opinion corium outside the RPV is entirely consistent with the thermocouples still functioning.
The fact that temperatures at the core bottom went up in unit 3 when they cut back on cooling water flow to stem the flooding of the basements and trenches, and dropped back again when they stepped it up again suggests that those thermocouple readings are not totally phantom readings.
Furthermore, dry well and RPV temperature readings (4 sensors in total) broadly went up and down together during those periods, which gives me some confidence that RPV readings are not totally bogus like the core water level readings turned out to be. See http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/plots/cur/out/plot-un3-t-T-full.png" .
What I don't have a clear picture of is how many MW of heat could have been conducted away by the 160 mm (BWR3) / 138 mm (BWR4) of steel of the RPV and of the (unknown) m2 of concrete floor inside the containment bulb.
The containment would eventually be pierced by a melted core if less heat is conducted away from the surface of the corium than is generated as decay heat inside, leading to a rise of temperature beyond the melting point of concrete. How realistic is that at this stage? We would need to understand the heat flow, which depends on conduction and convection.
If the RPVs are pierced at the bottom from a meltdown then water injected through the feed water pipe at the top of the RPV should leak out through the bottom, unless it all boils off inside the RPV from decay heat of any portion of the corium still left inside.
If cooling water leaks out of the RPV it may create a shallow pool inside the containment, at the bottom of which the corium will cause continuous boiling. Steam should be rising and perhaps recondensating inside the containment steel wall that carries heat away into the building. In that case the containment floor is not the only surface area removing heat from the corium.
If steam condensates on the containment walls and trickles down into the corium pool again, it could boil multiple times before eventually leaking out through damaged seals. That would explain why the apparently sufficient amount of cooling water in units 1 and 2 is less than the theoretical amount boiled away per hour by the predicted decay heat output.
That makes me wonder if the 5 cm gap between the steel and concrete portion of the containment could somehow be used for air-cooling the containment.
  • #10,597
tsutsuji said:
Concerning unit 4 they said that they could restore a vital pipe called "FPC-68" for that purpose : http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110709_02-e.pdf. Details explaining why they had to stop unit 3 SFP cooling equipment to allow starting the construction of the cover structure at unit 4 are provided in http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110708_01-e.pdf .
As Joewein says above, the cooling has been restored for the SFP at unit 3. What is making you think it has been restored for unit 1 as well ?
On http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/11071106_table_summary-e.pdf the SFP temperature at unit 1 is still marked today with "instrument failure" which makes me doubt much equipment has been restored there.
Concerning unit 2, the SFP circulating cooling system has been running since 31 May, according to http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110711_05-e.pdf page 3. It is also marked as "May 31 17:21 Started full-fledged operation of the alternative cooling system for the Spent Fuel Pool" on http://www.nisa.meti.go.jp/english/press/2011/07/en20110711-1-2.pdf page 5.
Considering the degree of site contamination, my hat if off to the Japanese. They have accomplished a lot.
  • #10,598
http://www.asahi.com/national/jiji/JJT201107120052.html At 8:40 AM on 12 July, a leak was observed on a surveillance camera, and the water treatment facility was manually stopped 10 minutes later. The leak location is in the Areva system, in the close proximity of the leak that occurred and was repaired on 10 July. The desalination facility is still running. Repairs are shown on http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110712_02-j.pdf (top picture is before repair, bottom picture is after repair).
http://www.nikkei.com/news/headline...1949EE3E0E291838DE3E0E2E5E0E2E3E3E2E2E2E2E2E2 The leaked volume was 10 l. The leak location was exactly the same as two days ago. The facility was started again at 4:58 PM after changing the fitting for a stainless steel one. It is thought that the zinc-coated cast iron one installed two days ago was corroded by the ferric sulfate flowing in the hose.
http://www.asahi.com/national/update/0711/TKY201107110485.html For the purpose of breakwater reinforcement work repairing the tsunami damages at the south of the water inlet, the silt fence will be opened 36 times for two hours each time in the upcoming 3 months to let the steel sheet pile driving boat to come and go. This rises the fear that some of the 1.2 terabecquerels in the water inlet could flow into the sea. The silt fence opening time being limited, Tepco says the consequence on the periphery is limited. Radiation measurements in the sea will be intensified. Local governments have been notified.
http://news.tbs.co.jp/newseye/tbs_newseye4773907.html the nitrogen hose will be connected on unit 3 on 12 July afternoon. The nitrogen injection will start at unit 3 this week (nitrogen injection is already being performed at units 1 & 2).
http://www.yomiuri.co.jp/science/news/20110712-OYT1T00502.htm  Minister Goshi Hosono said the details on a new middle to long term study team whose purpose is to study the decommissioning of Fukushima Daiichi will be announced on 19 July. They will have to find a solution so that the final disposal is located elsewhere than in Fukushima prefecture.
http://www.ustream.tv/recorded/15943265 NISA press conference, 12 July : The original heat exchanger at unit 1 SFP can be reused. Tepco hopes the SFP cooling system can be started at the end of July or within the first decade of August.
Operation of the diesel generators was carried out as follows due to the
preparatory construction of Yonomori line for duplication of line (July 11);
D/G 5A started (03:03), connected to the grid (03:19) and stopped
(09:07).
D/G 5B started (03:37) and connected to the grid (03:44).
D/G 6A started (04:17) and connected to the grid (04:21).
D/G 6B started (04:31) and connected to the grid (04:36).
・The power supply from Yonomori line was suspended due to the preparatory
construction for Yonomori line for duplication of line. (05:01, July 11)
http://www.nisa.meti.go.jp/english/press/2011/07/en20110712-1-1.pdf
http://www.meti.go.jp/press/2011/07/20110712005/20110712005-1.pdf page 23 : white smoke observed at unit 4 on 12 July 6:30 AM.
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110712_01-j.pdf page 2 : water injection into unit 4 reactor well and dryer storage pool started at 11:22 AM on 12 July. It had to stop at 12:03 because of a leak in the connection of the injection line.
  • #10,599
According to GE they are actually a Type T Thermocouples with a 350C upper limit. They are magnetically attached which is another big problem. Does anyone know of a magnet that still works when heated over 1000C? Only the thermocouples on the RPV head are attached mechanically.
[PLAIN]http://img89.imageshack.us/img89/7498/thermo.jpg
  • #10,600
[PLAIN]http://img89.imageshack.us/img89/7498/thermo.jpg[/QUOTE]
My bad, thermocouples were dropped for RG 1.97 per
http://pbadupws.nrc.gov/docs/ML1109/ML11098A049.pdf
You are correct about type T range. Thanks for the correction.
  • #10,601
joewein said:
On June 1 the remain decay heat output in unit 1 was 3.7 MW while in units 2 and 3 it was 6.3 MW, which is 0.26% of thermal output at shutdown. Over the next 8 months that will go down to 0.21% of thermal output at shutdown, so it's essentially steady now (http://mitnse.com/2011/03/16/what-is-decay-heat/" ), since most of the iodine-131 and other shortlived isotopes are largely gone.
Joe, the data you use to estimate the current heat output assumes that there was no leakage of nuclides as has happened at Fukushima.
The actual current heat output should be considerably less than those figures.
From your source:
"This data is not produced from measured data on the actual reactors at Fukushima, but from using a well established model that is routinely used to estimate decay heat from shutdown reactors.
#9044 Jorge Stolfi
once the fuel is completely molten, the radioactive elements that remain in the liquid corium will produce 30% of the decay heat power that would be produced by the intact fuel;
the other 70% of the decay heat power is due to more volatile elements that will end up elsewhere.
  • #10,602
Thanks for pointing that out. I had forgotten about that...
So assuming the cores completely melted in all three units, the current heat output of the cores should be more like 1.2 MW in unit 1 and 2.1 MW in units 2 and 3.
The balance of 2.5 MW in unit 1 and 4.2 MW in units 2 and 3 should mostly be in the leaked water, on RPV and containment walls and around pipes, wherever evaporated volatile isotopes could condensate or get leached out.
Does anybody remember how many curies of Cs-134 and Cs-137 were leaked into the atmosphere according to NISA estimates?
  • #10,603
What document is that from?
There is a lot that is unknown about thermal properties during a core melt event.
http://www.tec-sim.de/images/stories/lecturenotes-late-in-vessel-phenomena.pdf
On page 16 of that document:
Though in the TMI-2 accident no external cooling was available, the vessel wall did not experience any noteworthy thermal attack in contradiction to what all simulations predict to date. The thermal attack on the vessel wall was limited to a hot spot in which the internal vessel wall reached temperatures of ~1100°C in a region of approximately 0.5 meter width, which was rapidly cooled after approximately 1/2 hour.
There is the distinct possibility that molten material relocated out of the RPV without necessarily requiring the entire bottom head to fail. There's also the possibility that such a magnetically attached thermocouple became "no longer attached" to the vessel at some point.
  • #10,604
Considering the tens of thousands of gallons of water which have washed through the containment, those numbers would be an unlikely to achieve upper limit.
But with the good comes the bad - more from Jorge:
Jorge Stolfi said:
On the other hand the corium will contain many long-lived isotopes....
While the contribution of an element to the heat production rate is inversely proportional to its half-life (among other things), its potential for health damage is largely independent of it, at least for lifetimes up to a decade or two. So, while the corium keeps 30% of the decay heat production, it may include a larger fraction of the total health damage potentia of the original fuel.
Thus the decay from this point will be at a slower rate due to the predominance of long-lived isotopes.
In effect, we are now at the same point a plant which had a normal shutdown would have been - several decades later.
  • #10,605
Cobalt would be a Candidate (T_c ~ 1400K). This is the material with the highest Curie temperature I know of.
  • #10,606
Do you use a magnet that can withstand those temperatures when the sensor itself is only designed to measure 350C? It seems like that would be prudent to do so.
I'll have to do some more research and see if I can identify the magnetic material used.
Omega sells several type of magnetic thermocouples. The only note I could find stated "Magnet Will Retain 90% of Its Pull at 370°C (700°F)"
  • #10,607
http://www.nikkei.com/news/category...E1E2E2E68DE3E1E2E5E0E2E3E39790E0E2E2E2;at=ALL Tepco will install a new mainly-Toshiba-made backup system using zeolite for the water treatment facility, setting August as the target date. In addition to the present reverse osmosis desalination system, evaporation-enrichment systems will be installed in August and in October. Unit 4's SFP cooling system will be started in the last decade of July. Unit 1's SFP cooling system in the first decade of August.
http://www.meti.go.jp/press/2011/07/20110711008/20110711008-1.pdf This is a formal NISA request requiring Tepco to write a report about its plans concerning the safety of the SFP cooling systems for unit 1 and unit 4, reminding Tepco the deadline of July 17th as part of the "step one" of the "roadmap".
http://www.tepco.co.jp/cc/press/11071309-j.html (not yet translated into English) Tepco's report on the SFP cooling systems for unit 1 and unit 4, as a reply to the above NISA request.
http://www.tepco.co.jp/en/press/corp-com/release/11071109-e.html Tepco's report on the safety of the nitrogen injection at unit 3.
http://www.tepco.co.jp/en/press/corp-com/release/11071212-e.html this press release is simply called "Water leakage in the reactor building (non-controlled area)". It turns out it is not in Fukushima Daiichi but in Kashiwazaki-Kariwa unit 5.
http://www.tepco.co.jp/cc/press/11071302-j.html (not yet translated into English) This is the second installment of the "Study regarding current seismic safety and reinforcement of reactor buildings at Fukushima Daiichi Nuclear Power Station" and it is about unit 3. The first installment, published on 28 May, was about unit 1 and unit 4 : http://www.tepco.co.jp/en/press/corp-com/release/11052801-e.html
Do you remember the figure page 78 of http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110525_01-e.pdf (a slideshow on the "Effects of the Earthquake and Tsunami on the Fukushima Daiichi and Daini Nuclear Power Stations" published in May) showing "Installation of a Backup RHRS pump" to provide sea water cooling for unit 5 or unit 6 ? Whenever I was looking at that picture, I had the painful feeling that the hose would break on the sharp edge of the water intake bank. The artist who drew the picture was not wrong. This is really what happened on 3 July and you probably still have the "hose turned into a fountain" picture released on that day : http://www.tepco.co.jp/en/news/110311/images/110703_1.jpg in your mind. Here is a follow-up :
On July 3, the leakage of seawater at one of outlet piping in residual
heat removal system was detected at Unit5. Though we made countermeasures
to protect the pipe from concrete block corner, same piping condition was
found at the other place in the investigation. From the viewpoint of
preventive maintenance, we stopped residual heat removal system at 6:30
am on 13 July (outside temporary seawater cooling pumps stopped at 6:44
am) and replaced piping.
http://www.tepco.co.jp/en/press/corp-com/release/11071301-e.html
And, as usual, another leak today. Where ? At the water treatment facility of course :
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110713_01-j.pdf (page 1) Flushing was started at 11:00 AM on 13 July. While flushing was being performed, a leak was found near the coupling part of a chemical injection line at the coagulation-sedimentation facility at 01:07 PM. But it is a different location from the leak that occurred on July 10th and July 12th. Flushing has been stopped and the leak is being investigated.
http://www.nikkei.com/news/headline...19595E3E1E2E2848DE3E1E2E5E0E2E3E39F9FEAE2E2E2 the leaked volume is 5 l. Another PVC fitting is being changed for a stainless steel one. The target utilization rate of the facility is lowered from 80% to 70% for July. However 90% is set as the target for August. With an 80% rate, it would become impossible to reach the goal of treating all the 200,000 tons within this year.
http://www.asahi.com/national/update/0713/TKY201107130512.html the utilization rate for the week from 6 July to 12 July was 73%, which is 3 points lower than the 76% achieved a week earlier.
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110713_01-j.pdf (page 2) At around 01:00 PM, the portable monitoring post at the main gate was displaying a zero value. After checking there was nothing abnormal there, the power supply at the seismic-isolated building was restarted at 02:55 PM, which restored a normal value.
  • #10,608
Cs-134: 1.8E16 Bq, ~486.000 Curie
Cs-137: 1.5E16 Bq, ~405.000 Curie
Source: http://www.kantei.go.jp/foreign/kan/topics/201106/pdf/attach_04_2.pdf
  • #10,609
Nuclear plants have tried to eliminate use of cobalt due to neutron activation to Co60 which is a high energy gamma dose source.
  • #10,610
I don't think so, either. Obviously the designers of the reactors thought: "The RPV won't go beyond 350°C because it must not. If it does a failing temperature sensor is the least problem."
  • #10,611
Responding to a message of the Science Council of Japan, and with the purpose of learning the lessons from Japan, the French Académie des Sciences is publishing a report on the seismic and nuclear events in Japan. The first 2 parts on the earthquake and on the nuclear accident were published on 28 June with a number of attachments at http://www.academie-sciences.fr/activite/rapport/rads0611.htm . A third part on the medical consequences is not ready yet.
It is written in French, but an English translation is provided for the main text. Here is an excerpt :
The Japanese seismologists responsible for the forecast were convinced that the probability of an earthquake occurring could be calculated in a rational manner, using the definition of characteristic earthquakes for each region. The forecast map, therefore, had not made any provision for an earthquake of magnitude higher than 7.5 in the area closest to the continent and 8.2 closer to the trench. The Tohoku earthquake had a magnitude of 9.0-9.1. On the basis of this forecast, the tsunamis accompanying the earthquakes were not predicted to exceed 4 to 5 metres on reaching the coast. The Tohoku triggered tsunami measured between 15 to 20 metres. The Fukushima nuclear power station site had been built to protect the infrastructures from tsunamis less than 5.7m in height upon reaching the coastline, whereas this tsunami just off the reactor sites measured 14 m with respect to the sea’s normal level.
The main error made by the Japanese specialists was to consider that the past century of seismic events was representative of the continuous, ongoing subduction process. It is, however, known that subduction zones can produce earthquakes equal to or higher than magnitude 9, with lateral movements in excess of 20 to 30 metres, due to stress accumulated over several centuries, i.e., a much longer period than the Japanese specialists had used for their forecasts. The fact that major earthquakes, magnitude 7.5 to 8 had relieved part of the elastic deformation did not preclude that a megathrust earthquake could follow, and indeed this was the case on March 11, 2011. The seismic energy dissipated over the past century only represents 20% of the energy represented by the progressive dip of the Pacific plate sliding under the Japanese archipelago.
The geological and historic records show that very big tsunamis had hit the Tohoku coastline in years 1611 and 869, and the residual traces are much greater than those left by the earthquakes over the past century (although the lesser magnitude earthquake that occurred in 1896 did produce some really impressive damage)! The cycle for major tsunamis occurring lies between 500 and 1,000 years.
The building of a dense GPS network (30 km between stations) following the Kobe earthquake in 1995 allows scientists to demonstrate that the elastic deformation observed in Japan as a result of the progressing Pacific Plate corresponded to a slip rate close to 80 mm/year, i.e., almost 100% of the subduction rate and not 20% as had been conjectured.
The Tohoku earthquake serves to show that any forecast based on recent data proves inadequate. We must therefore take both historic and geological data into account if we wish to characterise seismicity over a span of at least several centuries, better still over several millenniums.
pages 10-11 http://www.academie-sciences.fr/en/rads0611_en.pdf
  • #10,612
I'm not sure the engineers of 40 years ago had the tools we are using to critique their reasoning.
  • #10,613
While they wouldn't have known of the 2004 Indonesian tsunami, the story about big tsunami in Alaska would have been in their local newspapers.
Tsunamis are a well known feature of the Pacific rim, especially Japan.
October 1707 an 8.4 earthquake and tsunami 25.7 meters high hit the Kochi Prefecture
April 1771 earthquake magnitude 7.4 near Okinawa - tsunami is thought to have killed about 12,000 people, the highest seawater runup on Ishigaki Island, range between 30 meters and 85.4 meters.
Nov 1854 The Ansei Quake on the south coast of Japan, was actually 3 quakes, two magnitude 8.4 quakes and a 7.4 quake. The first on near what is today Aichi Prefecture and Shizuoka Prefecture with tsunami. maximum wave of 28 meters at Kochi, Japan, the earthquake and tsunami killed 3,000 people.
June 1896 earthquake in northeastern Honshu - tsunami reached a height of 100 feet, 1896 (magnitude 7,2 / wave height 36m)
September 1923 The Great Kanto Earthquake - eastern Japan devastated Tokyo, Yokohama and the surrounding areas, caused tsunamis with waves reaching 12 meters.
1933 (magnitude 8,4 / wave height 28m): http://en.wikipedia.org/wiki/1933_Sanriku_earthquake
1964 in Alaska (at the time Fukushima was being designed) Mag 9.2, tsunami 27-foot (8.2 m)
The waves produced by the 2004 Indonesian tsunami were (27m) high and killed 230,000 people, that seems a fair warning to the current generation.
I agree that we should let bygones be bygones, but let's not make excuses for bad decisions.
  • #10,614
I don't think that's the reason. Attitude towards safety has changed dramatically over the last decades. I have an professional circular hand saw from my father, solid carpenter quality form the 60's but you have to be very carefully not to amputate your fingers. This does tell us something about the accepted risk >40 years ago.
  • #10,616
The ability to fail gracefully indeed should be the main development interest of the nuclear industry imho.
Nothing else will be able to generate acceptance in local populations for building new NPP.
At least this provides us with dependable information that the temperatures never reached some Curie temperature (which one remains the question).
(Edit: At least if we assume that the thermocouples are not dangling in thin air now...)
I disagree.
Traditional practice in German and Austrian construction trade is to dimension flood protection for nuclear plants, hydro dams etc after the highest flood you could possibly expect in the course of 10000 years. We even have a word consisting of three composite words for this: "http://de.wikipedia.org/wiki/Bemessungshochwasser" ".
The Japanese know from their ancients the height of former tsunamis. (Remember the stone monuments already mentioned several times in this thread.)
So they had the advantage of having authentic first-hand data.
But the warning stones of the ancients were - simply ignored!
  • #10,617
Well and clearly stated. Bears repetition until the brutal lesson sinks in.
Respectfully submitted,
Steve
  • #10,618
Even if we are to (falsely) assume that the engineers could not have known of these geological risks when the plant was designed, that does not exonerate the nuclear industry of it's failure to correct the problems over the past 40 years. If the industry operates under the assumption that mistakes made in the past may be ignored because the plant was designed long ago, then the industry is doomed to repeat failures like Fukushima, Chernobyl and TMI.
They cold have shut the plant down for safety upgrades at any time over the past 40 years, but the nuclear industry chose to leave it running 'til 40 minutes before the tsunami hit.
Now they feed our school children with beef containing >3,000 Bq/kg of Cesium supplementation.
  • #10,619
That's interesting. The position of the Torness nuclear power station in eastern Scotland, and other British coastal reactors, did not take account of the Storegga Slide, which caused a large tsunami in about 6100BC.
  • #10,620
Since NISA has evaluated the injection way we reported as being valid and
the preparation for the injection has been completed, we will conduct the
injection of nitrogen to the reactor containment vessel of Unit 3 from
around 8 pm today.
http://www.tepco.co.jp/en/press/corp-com/release/11071402-e.html
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110714_01-e.pdf section view of the PVC fitting connecting the chemical line with the contaminated water pipe at the Areva system. It shows the one that failed yesterday, but if my understanding is correct, this drawing can also apply to the one that failed on 10 July.
http://www.asahi.com/national/update/0714/TKY201107140324.html the repair at the Areva facility is difficult because of the 100~150 mSv/h radiation. The repairing method needs to be studied again.
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110714_03-j.pdf(page 1) the repair at the Areva facility was completed at 12:07 PM, 14 July. (page 2) the monitoring post at the main gate was displaying a zero value again on 13 July 10:00 PM. The data receiver at the seismic-isolated building will be repaired or changed.
http://news24.jp/articles/2011/07/14/07186434.html and http://news.tbs.co.jp/newseye/tbs_newseye4775950.html ( ) The new water treatment facility, called "Sally" left Yokohama Port this morning. Its start is planned for next month. Sally is made by Toshiba, IHI and US company Shaw. Its decontamination factor is up to one million. According to Toshiba, it can be used as a backup of the Kurion-Areva system.
http://www3.nhk.or.jp/news/genpatsu-fukushima/20110714/0720_3_118nin.html Tepco is unable to check for radiation exposure 118 workers who worked in April, and 14 workers who worked in March at Fukushima Daiichi, because their whereabouts are unknown.
About Tokai NPP:
[Japan Atomic Power Company] says some parts were also found missing from a device that injects coolant into the reactor. It also discovered cracks in equipment attached to the upper parts of the reactor.
July 13, 2011 http://www3.nhk.or.jp/daily/english/13_38.html
The [NISA] found that the level of quake-resistance of the electrical equipment at Tokai Daini nuclear power plant in Ibaraki Prefecture was below the standard set by power companies.
July 08, 2011 http://www3.nhk.or.jp/daily/english/08_01.html
http://mytown.asahi.com/ibaraki/news.php?k_id=08000001107090002 At 7:40 AM, 8 July, at Tokai NPP, a worker passed the 2 mSv / day limit while working at the removal of a control rod actuator. With the addition of the other tasks he performed on that day, his total exposure reached 3.3 mSv for that day. The reasons were: 1) forgetting to install the thick radiation shield . 2) forgetting to check the presence of that thick shield 3) While trying to fasten a thin shield with tape, he came too close to the radiation source. It is the first time ever that a worker passes a radiation limit in this plant.
http://www.asahi.com/special/10005/TKY201105110471.html (article dated 15 May 2011 about the sequence of events in March) Although Onagawa NPP achieved cold shut down at around 01:00 AM on 12 March, it took 3 and a half days to achieve cold shut down at Tokai NPP. At 02:00 AM on 12 March the pressure was 58 atmospheres, and it reached 60 atmospheres at 03:00 AM. Injecting water and operating valves, they managed to prevent that the fuel rods emerge out of water, but the water level had a 70 cm variation. Offsite power was restored in the morning of 14 March, and cold shutdown was achieved in the following night. This is more than twice the normal duration to achieve cold shutdown.
49K
  • · Replies 41 ·
  • · Replies 2K ·
60
463K
20K
  • · Replies 763 ·
280K
  • · Replies 38 ·
16K
12K
