What is this unique op-amp's name and how do I find Vout?
  • Thread starter Thread starter Femme_physics
    Op-amp
The discussion centers on identifying a unique op-amp configuration and calculating its output voltage (Vout). Participants note that the circuit features Vin connected to both the positive and negative inputs, which is uncommon and leads to confusion about its operation. The consensus is that Vout can be determined as Vout = Vin/4, using nodal analysis and Ohm's law, despite the circuit's unusual feedback arrangement. There is also a discussion about the practical applications of such a configuration, with some participants suggesting it serves more as an academic exercise than a real-world application. Overall, the conversation highlights the complexities of analyzing non-standard op-amp circuits while encouraging the use of fundamental electrical principles.
Femme_physics
I have never seen anything like this ! Are you certain you have the correct diagram.
There are applications where Vout is connected back to the - input (this gives a gain of x1) but this circuit seems to me to show some inconsistencies.
I cannot see how Va can be equal to Vb.
I look forward to see the response of others
Oh, that reminds me! I forgot to ask my teacher about what you confirmed was correct! I have a class with him sunday, I will definitely remember.
Yes, I'm looking forward to other replies as well-- even though you seem to have great knowledge at the field yourself.
The first thing I did was re-draw your circuit... I kept R1, R3 and R4 exactly as they are but I then drew R2 just above R3 connecting to the - input.
The connection from Vout to point b remains as it is.
This just did not 'look right'...
Thank you for your comment:blushing:
I love op amps... they look very complicated but the principles are straight forward and I like sorting them out.
It's a tricky divide by 4 circuit. That is, Vout = Vin/4. To analyze, recognize that the feedback from Vout to b will make a = b = Vout. Then forget about the op-amp and concentrate on the resistor network, putting in a controlled source "Vout" to stand in for the the op-amp:
All resistors are 5KΩ.
Thanks gneill I tried something like that to make Vout = Va =Vb and got tied in Knots !
It is not really a normal question about op amps... difficult to see this as a practical application.
Yeah, you might say that it's more of an academic exercise :smile:
As for its practicality, I suppose one would have to check to see how accurate the division operation is for the given component tolerances as compared to other configurations.
I forgot to add that the supply voltages are +-10
Is there a name for this op-amp, gneill?
REally? That's it? That's the answer?
I can think of a name for it (if it doesn't already have one):devil::devil::devil:
I don't know if there's any specific name, but it certainly falls under the general heading of non-inverting amplifier. I'll admit that the positive feedback loop in addition to the negative feedback loop makes it a tad unusual. And yes, the amplification factor is 1/4. You should see if you can derive it from the hints given.
Can you elaborate more please? I can't see the logic of just dividing by 4...is it purely based on KVL and KCL?
Yes, KVL, KCL, the usual analysis tools. If you can see how the diagram I gave arises (here it is again):
Then you can start from there. Suppose that all resistors are R. Apply nodal analysis at the node labelled Vx. You'll get an equation involving Vin, Vout, and Vx. Make Vx vanish by noting that i3 = Vx/(2R), and that Vout = i3*R. Re-arrange what's left to find Vout in terms of Vin.
Just in case it's not obvious where the "reduced" circuit came from, here it is again but with the op-amp shown in place. Note that all I really did was to make the op-amp into a controlled source.
If you think about it, the op-amp is in a voltage follower configuration with the output fed back directly to its "-" input. So it really is a controlled source: it's output is 1x the voltage across the resistor at its + input.
From what I understand, it appears you're treating the circuit as though the Vin is our V+ and the minus ends are the plus leg of the transistor and the ground? Such as:
http://img841.imageshack.us/img841/1319/elez.png
I don't know how much that makes sense?
Yes, it is like that.
But your Sum Va is not quite right.
You're forgetting the voltage of the controlled power supply, which is the same as Vout.
I'm afraid gneill left that out of his (otherwise neat and insightful) drawing.
:confused: It's the diamond shape at the bottom left, labelled with the carefully concealed clue "Vout".
Sorry!
Yes it is there.
@Fp: so you should include Vout in your equation.
@FP: also note that your path V(b) should include the voltage drop across R1 due to I1.
:eek:
OK, rather surprising! but ok..
:shy:
So I3R4 = Vout?
Ok, think I got it.
http://img72.imageshack.us/img72/6636/pitaron.jpg
Femme_physics said:
:eek:
:shy:
How so?
Femme_physics said:
So I3R4 = Vout?
Yes.
Femme_physics said:
Ok, think I got it.
Looks good!
Don't forget to use Vout=I3R4.
Great! Thanks. Will do it now (had to take a lil nap :P )
How so?
Because I'm wondering...can I solve all of these op-amps questions I had with just KLV and KCL?
That's also what I do between a couple of difficult problems. ;)
Yes.
I was wondering when you would start doing that. :)
Yes.
Oh! If you could show me how!
We weren't taught that properly.Edit: How can you tell me for sure I3R4 = Vout? What is your basis for that?
You just did.
I3R4 = Vout, because Vout is across R4 and the current through it is I3.
This is just Ohm's law.
Femme_physics said:
I don't want to start a new thread, so I will just ask here. Can I use Kirchhoff law to find Vout here?
http://img194.imageshack.us/img194/5046/webcam1322988230.png
Yes you can.
Just apply the following rules:
1. Treat the op-amp as if its inputs + and - are not connected to the circuit.
That is, they draw no current in KCL, and they are not part of any loop in KVL.
2. Set V+=V- and solve using KCL and KVL, unless you find it's impossible, or if Vout would come outside its bounds.
Yes, sure you can, but it's like using a flame-thrower to cook your meal. :-p
Once you grasp the idea of the op-amps, there's no need of such tools.
You just did.
What is the meaning of Vout though? The last voltage drop in a loop?
Yes you can.
But, well, where are my loops? I can't see any loops. I just see lines!
Perhaps you're right, but I want it to provide me with a basis of understanding. :smile:
Vout = the output voltage
Each circuit typically has an input and an output.
You put an external signal on the input, like a measured temperature.
And you get for instance an amplified signal on the output, that you can use to control an external electro-magnet.
Consider any 2 Earth's connected.
Consider Earth and Vin connected through a battery with voltage Vin.
Consider Earth and Vout connected through a battery with voltage Vout.
There are no connections through an op-amp.
I had a long reply for that yesterday, but somehow got an error. :-/
So, I'll start rewriting it.
So, in this case...
http://img195.imageshack.us/img195/3663/thehell.jpg
So, this is what I'm getting out of all that:
http://img818.imageshack.us/img818/7315/gettingout.jpg
Am I following you?
  • #31
Yeah, I've had that sort of thing happen to me too.
Femme_physics said:
But what does it do?
Nothing is going in and nothing is going out.
It can't be a very useful circuit.
Oh, I know! It's for an exercise!
Am I following you?
Yep, yep, yep, and yep.
As for the Vout question... perhaps you should make a KVL loop including Vin and Vout?
Or just apply Ohm's law using the difference in voltages?
  • #32
Heh.. yeppers ;)
But how can I apply loop to an OPEN circuit? I need a beginning and I need an end. Hmm. Oh, I get to call the end Vout, eh?
http://img444.imageshack.us/img444/6113/taktak.jpg
But I'm not sure how do I know that I1 = I2. My teacher told me that, but all i know is that
Sigma I = 0 ; It -I1 -I2 = 0
But that doesn't tell me I1 = I2
  • #33
That's it, except for the RL that shouldn't be there.
Yeah, actually I1 = -I2, since you drew the arrows in opposite directions, but their magnitudes are the same.
The key thing is that the op-amp does not draw current.
  • #34
I'm still back on the original circuit, the one with 100% negative feedback combined with some positive feedback. Without analyzing it, I'm tipping that this arrangement gives it a very high input impedance. In some applications, a buffer circuit that does not load the signal source can be a useful isolating stage.
  • #35
True, but we have different valued resistors. Different valued resistors mean different currents.
Gotcha :smile:
Will reply to that soon and try to solve the original circuit. :) Thanks.
  • #36
Not in this case.
KCL says that current in equals current out.
The current can not go anywhere else (since it doesn't go into the op-amp).
It's the same when 2 different resistors are in series.
The current through both of them is the same.
  • #37
Agreed.
Right, they both go to the minus end of Vi. How does that necessarily mean they're equal?
When 2 different resistors are in series 2 different currents flow through them. If this case is the same as 2 different resistors in series, I1 should not equal I2.
How can you prove it?
Edit: Oh and... :smile:
http://img46.imageshack.us/img46/1332/hardar.jpg
Did I get it?
Haven't figured out Av for a comparator, I'll it up as soon as I see I'm right so far.
  • #38
Femme_physics said:
Agreed.
Huh? :confused:
Consider this circuit:
This is "in series".
The same current flows through both of the resistors.
  • #39
I like Serena said:
Huh? :confused:
I...can't believe I forgot that! Oops, my bad. :rolleyes: Thanks. :shy:
PS: I edited the reply above...You're fast!
  • #40
Did I get it?
In your 2nd picture you connected the left leg (b) to the ground.
It's not connected to the ground but to a "controlled" voltage source giving off a voltage of Vout.
In other words, your Sum V(b) is not right.
It should include Vout.
  • #41
I'm not fast... you're too slow! :biggrin:
  • #42
You're right. I forgot. I didn't have a laptop at work today since I forgot my power cord... :frown:
Also,
Tried to solve this
http://img194.imageshack.us/img194/5046/webcam1322988230.png [/QUOTE]
http://img51.imageshack.us/img51/1160/cannot.jpg
My only problem was trying to solve it using only KCL and KVL...as you can see.
True :wink:
  • #43
Oh, it can be solved using only KCL and KVL, and I recommend doing so if only as a verification.
In your 1st method you made a calculation mistake (which you can find by verifying with the 2nd method).
In your KCL/KVL method you didn't use a proper loop.
  • #44
Yes, that's what am trying to do :smile:
Oh, yea, Vout = 6. Oops!
Ok, hmm. What's wrong with my loop?
  • #45
Oh, yea, Vout = 6. Oops!Ok, hmm. What's wrong with my loop?
Let's see, first you go up from Earth to 2 [V].
We're at V- now aren't we?
Then you follow resistor R1 down, which is good...
And then we're at Earth again.
All finished! :smile:
... except that you moved on to R2, and then Vout...
But how did you get there? :confused:
  • #46
  • #47
Femme_physics said:
Because there are 2 ways to get to the ground. Yours is easier, admittedly, but I don't see Vout in your equation?
Okay, let's do this again and follow a different path.
First 2 [V] up from Earth to V-.
Then we follow R2 down (instead of R1).
Then we go down with Vout.
... and we're back at the ground!
Now we have 2 loops...
Can you solve them?
  • #48
Femme_physics said:
Also...->
http://img196.imageshack.us/img196/4086/tryouttry.jpg
Yes?
Your equations are good! :smile:
But... your solution isn't! :frown:
If you substitute your solution in the first equation for V(a), you'll see it doesn't fit.
  • #49
Not in this case.
But...but the current splits! How is this the same as resistors in series?
Also, I guess I made the loops in reverse than what you had planned but I'm just trying to see if I got the right loops:
http://img194.imageshack.us/img194/9471/yeathis.jpg
http://img842.imageshack.us/img842/8396/iriririr.jpg
I love it how you check up on my numbers, not just on my method. I guess you know I have a tendency to slip :wink:
Ok,
I got now,
I1 = 0.6 mA
I2 = 0.3 mA
I3 = 0.3 mA
Vout = I3R4 = 0.0003 x 5000 = 1.5 [V]
  • #50
That's because the current doesn't split.
Any reason you think it does?
I'm afraid I didn't plan anything. You did the planning.
I just followed your loop and found it's not consistent - you made some sort of a jump.
But you have the right loops here.
Femme_physics said:
These are the right loops!
And I1=-I2 because of KCL.
(Note the minus sign.)
Ok,
I got now,
I1 = 0.6 mA
I2 = 0.3 mA
I3 = 0.3 mA
Yeppers! :)
It's a divide-by-4 circuit!
