Shield speaker magnet from activating reed
The discussion focuses on shielding a speaker magnet in a model train setup to prevent it from activating a nearby reed switch. A suggested solution involves using a ferrous material, like iron, to create a shield that can deflect the magnetic field away from the reed switch. One participant recommends bending a flat piece of iron into a box shape around the speaker to effectively block the magnetic influence. Concerns about whether ordinary iron would become magnetized were addressed, indicating it would not strongly magnetize. Overall, the conversation emphasizes finding an effective thin material to mitigate unwanted magnetic activation.
Harvey Sherma
My question pertains to model trains. I use a magnet under my last car to activate computer commands via a reed switch. One locomotive has a speaker placed near the bottom and the magnet of the speaker activates the reed switch - which I don't want it to do. One thought to correct this is to place a thin substance under the locomotive, between the speaker and the reed, this substance would block/distort/weaken the magnetic strength. It would need to be thin. Is there such a material. I tried aluminum paper but that did not work.
Thanks,
Harvey
Thanks,
Harvey
It needs to be ferrous (like iron) in order to deflect/route the magnetic field.
Try bending a flat piece of iron so that it forms a 4-sided box around your speaker. Drill holes in the diaphram side of the iron strip before you bend it around the speaker. This will divert the external magnetic field lines closer to the speaker, instead of letting them spray out farther where they can affect your reed switch. Try to use the thickest iron strip you can, to avoid having it saturate from the magnetic field so close to the speaker magnet.
KI6EGL
Thanks for the quick reply. One question I have regarding iron is whether this would eventually become magnetized?
Harvey
i used a peach can to shield a subwoofer that was making my TV screen purple.
It was just right diameter to go around the speaker magnet. I cut it tall enough to cover the exposed part of the speaker magnet's bottom and sides.
Ordinary iron won't become strongly magnetized. But i think you want sides on your shield ,as Berkeman suggested.
Many cans are aluminum these days- check with a refrigerator magnet.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
