Understanding the Basic Operator Equation for Quantum Mechanics
  • Thread starter Thread starter genericusrnme
    Operator
genericusrnme
Can someone explain to me how
H(\sum_n w_n |a_n><a_n|) = \sum_n w_n(H|a_n><a_n|-|a_n><a_n|H)
I've done this before and I remember being confused about it before then finding out it was something simple.. I should really start filing my notes away for such an eventuality :frown:
I can't seem to work out what the next step is at all.
What you wrote is not correct. If you take an expectation value of your expression in the mth state, you'd find 0 on the RHS. We can find a correct statement if we consider the operators
O_L = \sum_n w_n (H| a_n \rangle )\langle a_n| ,
O_R = \sum_n w_n | a_n \rangle (\langle a_n|H) .
The expectation values in an arbitrary state are equal:
\langle a_m | O_L | a_m \rangle = \sum_n w_n \langle a_m |H| a_n \rangle \langle a_n| a_m \rangle = w_m \langle a_m |H| a_m \rangle,
\langle a_m | O_R | a_m \rangle = \sum_n w_n \langle a_m | a_n \rangle \langle a_n|H| a_m \rangle = w_m \langle a_m|H| a_m \rangle ,
where in both cases we used \langle a_n| a_m \rangle = \delta_{nm}.
So in this sense, O_R=O_L: we can let the operator act from the right or left side. This is the same way that expectation values work
\langle a_n | H | a_m \rangle = \langle a_n | (H | a_m \rangle ) = (\langle a_n | H) | a_m \rangle.
We can therefore write
H \left( \sum_n w_n | a_n \rangle \langle a_n| \right) = \frac{1}{2} \sum_n w_n \Bigl[ ( H | a_n \rangle ) \langle a_n| + | a_n \rangle (\langle a_n|H) \Bigr].
Yeah, I kept coming to that conclusion too yet what I wrote is what is in Sakurai's book..
i\ \hbar \partial_t \rho = H \rho \neq -[\rho , H]
Where \rho = \sum_n w_n |a_n \rangle \langle a_n |
I'll attatch an extract
OK, the point there is that \rho does not satisfy Schrodinger's equation so i\ \hbar \partial_t \rho \neq H \rho. Instead you have to use
i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \langle \alpha^{(i)},t_0;t | = \left( i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \right) \langle \alpha^{(i)},t_0;t | + |\alpha^{(i)},t_0;t \rangle \left( i \hbar \frac{\partial}{\partial t} \langle \alpha^{(i)},t_0;t | \right)
and
i \hbar \frac{\partial}{\partial t} \langle \alpha^{(i)},t_0;t | = - \left( i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \right)^\dagger .
The derivation I gave above is valid for time-independent states and wouldn't work here.
Ah!
I remembered it being something simple :L
Thanks buddy :biggrin:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
